The Torture Continues....First Leak Then Clog! HELP!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2012, 11:01 PM   #1
Hello Friends,
I want to thank all of your for your advice in replacing a length of corroded pipe with PVC. Normally, one can take dirty and disgusting satisfaction in a job well done. And I think I did a pretty good job for my first time, BUT
Now the sink fills up and the water goes nowhere...not even a little. It should have told me something when I cut the old pipe and whole lot of water came out. Normally, I would think the clog had something to do with my repair, but please have a look at the picture below. Water is leaking from the area circled, which is well below and to the right of my repair. So I know water is getting that far. If you can't see it close enough, it is a copper pipe going into a larger iron pipe (waste pipe I think). Water is leaking RIGHT where the two meet.
So I think it's safe to assume that somewhere between the end of that copper pipe and the sewer system, something is blocking it...perhaps a curious mouse crawled into the pipe when it was broken. There is a big iron "U" to the right, that I don't know the purpose of.
I need to get the drain working again or my wife is gonna kill me. Can ANYONE tell me the quickest, cheapest, least disgusting way to solve this problem?
I am REALLY sick and tired of being dirty, wet and tired.
vintshave is offline   Reply With Quote
Old 06-23-2012, 09:23 AM   #2
MarginallyQualified
Rewards Points: 2,464
SSDR same stuff different room
Originally Posted by vintshave View Post
Hello Friends,
I want to thank all of your for your advice in replacing a length of corroded pipe with PVC. ...And I think I did a pretty good job for my first time, BUT
Apply those same lessons to this situation.
Old 06-23-2012, 11:54 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Attachment 52858
Disconnect pipe at the point of repair. Cable the drain line, resemble.
Old 06-23-2012, 03:49 PM   #4
Cabling is not working. The clog, whatever it is, seems as hard as a rock
Old 06-23-2012, 04:15 PM   #5
Plumber
Rewards Points: 452
OK. How far did you cable? Do you know where the blockage is? How big is your snake? And explain if possible what those pipes serve in your picture.
Details please
Old 06-23-2012, 07:39 PM   #6
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
i would hate to have to replace that stack. Is that branch half in concrete?
wctekkk is offline   Reply With Quote
Tags
clog , drain , pumbing sink
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 11:15 AM
Plumbing leak in basement - HELP jamieblosser Plumbing 2 06-16-2011 12:44 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 10:27 PM
Sewer Line Continues to clog. Just Some Guy Plumbing 16 08-24-2009 11:38 PM
