-   -   The Torture Continues....First Leak Then Clog! HELP!! (http://www.diychatroom.com/f7/torture-continues-first-leak-then-clog-help-147946/)
vintshave 06-22-2012 10:01 PM
1 Attachment(s)
Hello Friends,
I want to thank all of your for your advice in replacing a length of corroded pipe with PVC. Normally, one can take dirty and disgusting satisfaction in a job well done. And I think I did a pretty good job for my first time, BUT
Now the sink fills up and the water goes nowhere...not even a little. It should have told me something when I cut the old pipe and whole lot of water came out. Normally, I would think the clog had something to do with my repair, but please have a look at the picture below. Water is leaking from the area circled, which is well below and to the right of my repair. So I know water is getting that far. If you can't see it close enough, it is a copper pipe going into a larger iron pipe (waste pipe I think). Water is leaking RIGHT where the two meet.
So I think it's safe to assume that somewhere between the end of that copper pipe and the sewer system, something is blocking it...perhaps a curious mouse crawled into the pipe when it was broken. There is a big iron "U" to the right, that I don't know the purpose of.
I need to get the drain working again or my wife is gonna kill me. Can ANYONE tell me the quickest, cheapest, least disgusting way to solve this problem?
I am REALLY sick and tired of being dirty, wet and tired.
Attachment 52858
TarheelTerp 06-23-2012 08:23 AM
SSDR same stuff different room
Originally Posted by vintshave (Post 949359)
Hello Friends,
I want to thank all of your for your advice in replacing a length of corroded pipe with PVC. ...And I think I did a pretty good job for my first time, BUT
Apply those same lessons to this situation.
TheEplumber 06-23-2012 10:54 AM
199 Attachment(s)
Attachment 52858
Disconnect pipe at the point of repair. Cable the drain line, resemble.
vintshave 06-23-2012 02:49 PM
Cabling is not working. The clog, whatever it is, seems as hard as a rock
TheEplumber 06-23-2012 03:15 PM
199 Attachment(s)
OK. How far did you cable? Do you know where the blockage is? How big is your snake? And explain if possible what those pipes serve in your picture.
Details please
wctekkk 06-23-2012 06:39 PM
i would hate to have to replace that stack. Is that branch half in concrete?
