Top Water Heater Termostat Popping - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2011, 08:25 AM   #1
Top water heater termostat popping
Both thermostats have been replaced and the water heater was flushed for sediment less than a month ago. Please help!?
SupraTT is offline   Reply With Quote
Old 03-05-2011, 08:41 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Check the wattage rating of the elements. Then figure out the normal amperage draw of them if it is not listed on the model # plate and check the draw with an amprobe/amps meter. W=E x I. Watts = volts x amps. Amps = watts/volts. May be drawing too much power/overheating due to corroded connections etc.
Old 03-05-2011, 08:54 AM   #3
I'll test it shortly. I forgot the mention that the heater produces hot water its just that it runs out quickly and the top thermostat pops quickly.
Old 03-05-2011, 09:28 AM   #4
The elements are 4500 watts.
The top element read 13.5. Bottom element read 13.2
Old 03-05-2011, 09:30 AM   #5
Hvac Pro
yuri's Avatar
Probably the dip tube which is supposed to force the cold water from the cold inlet at the top of the tank to the bottom is cracked or broken off inside the tank. Therefore ALL the heat is trapped at the top level. Google: dip tube for more info. Also click on IMAGES in google.
Old 03-05-2011, 09:31 AM   #6
Googling now.
Old 03-05-2011, 09:49 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Why would that cause the thermostat problem?
Journeyman Plumber
Old 03-05-2011, 09:51 AM   #8
Do you know what would?
After reading it looks like a broke dip tube would cause lukewarm water. Also, seems like the water heater wouldn't overheat and trip the upper thermostat. I could be wrong though. I don't know much about water heaters. Actually I know nothing.
Old 03-05-2011, 10:25 AM   #9
Hvac Pro
yuri's Avatar
Just a theory I have. Water gets stratified in the tank and w/o a crystal ball I don't know what is going on in there either.
Old 03-05-2011, 12:31 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Check that both t-stats sit firmly against the tank, if not they do not sense the temp. correctly and will overheat and trip out.
It might be worth replacing them both again. It has been known that they can be bad new out of the box.
Coastal South Carolina
Old 03-05-2011, 03:17 PM   #11
Both t-stats are firm against tank. Retested resistance and continuity both checked out fine. I'm at my wits end.
Old 03-05-2011, 04:09 PM   #12
A "Handy Husband"
rjniles's Avatar
The resistance of the elements is fine, but test from each element to the side of the tank. That reading should be infinity (very high resistance). If you get a low resistance, the element is grounded to the tank and is bad. I hope it is needless to say, the power must be off for this test.
If this test is good, replace the t-stats again. The problem with a bad t-stat is that either one can cause the reset in the upper stat to trip.
Old 03-05-2011, 04:10 PM   #13
I tested both sides of both elements with the power off. Looks like I'll be replacing the t-stats again.
Old 03-05-2011, 04:28 PM   #14
A "Handy Husband"
rjniles's Avatar
Damn, you are fast. I posted at 5:09 and you tested both elements and posted your answer at 5:10. Did you really make the tests?
Old 03-05-2011, 04:38 PM   #15
I had already tested them before you posted about an hour before.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
