Which Tool Do I Use To Free This Tap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2011, 04:10 PM   #1
Never try, never know
Genghis_McCann's Avatar
which tool do I use to free this tap?
The hot water tap in my sink isn't connecting. It turns but no water comes out ( the water IS on). Somehow turning the tap isn't opening the valve.
It's a relatively new tap, just installed 2-3 years ago. It may still be under warranty, but I wanted to look at it first to see if there was a simple solution.
Here is the tap.
There are no screws on the upper side of the sink, so I assume access is from below, where the tap is secured by a plastic nut about 1'' diameter with four tabs on it. I tried to remove it with the tool on the left and one of the tabs promptly snapped off!
1. What tool should be used to remove this plastic nut?
2. is it a regular right hand thread, turning anticlockwise to remove?
Or should I simply be calling the company that installed it?
Thanks.
Genghis_McCann is offline   Reply With Quote
Old 09-11-2011, 06:57 PM   #2
DIY staff
Rewards Points: 7,174
The tap handle is held on by the bell shaped trim under the handle.
Grab the handle with one hand and the bell shaped thing in the other hand--unscrew the bell and lift it off.
Nothing to do under the sink.
Genghis_McCann (09-12-2011)
Old 09-12-2011, 09:28 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've had them before where they have been GROSSLY over tightened above, and it was necessary to loosen the nut and washer and supplies below to get it out of the hole to work on it. 99% of the time, however, this should not be the case. Turn counterclockwise with your hand, and the thing should start lifting right up as it spins.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 09-12-2011, 10:15 AM   #4
Thanks Alan / Mike. I think I'm in the 1%
Even with both hands and rubber gloves for traction I can't budge the bell.
I'll call Sweitzer's, who installed it, and ask them to come out and have a look.
My hat is off to plumbers. Every job I try to do myself seems to have an unforeseen problem that brings a ten-minute job to a grinding halt! I'm successful in plumbing about 20% of the time Now carpentry, on the other hand ....
Old 09-13-2011, 09:16 PM   #5
DIY staff
Plumbing is an adventure---The more you do the easier it gets---For most folks not knowing the parts needed for a job is the hardest part----
So often a one hour job turns into four hours of frustration with several trips to the store.
Old 09-14-2011, 10:06 AM   #6
Rewards Points: 1,772
Is the aerator on the spout clogged or are you sure it is the valve?
bob22 is online now   Reply With Quote
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
