Is This Too Many Branches For One Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2008, 10:38 AM   #1
Is this too many branches for one pipe?
I am totally renovating my basement bathroom; There is one- 1/2" cold water pipe that goes to the sink, shower and toilet. I would like to run the first floor bathroom toilet to this same pipe. The reason is to sheetrock directly against the ceiling joist in the basement bathroom. Currently the first floor bathroom toilet line is hanging down from the basement bathroom ceiling. It would be easiest to tie into the 1/2" cold water line in the basement bathroom to the first floor bathroom toilet. I hope this makes sense. In other words; a shower, sink and two toilets on one 1/2" pipe, the presssure is very good. Thank you for your advice.
teachtech is offline   Reply With Quote
Old 02-08-2008, 11:22 AM   #2
Rewards Points: 1,500
You will probably get away with it. It will be rare that both toilets were flushed and therefore refilling at the same time you are also taking a shower.
Old 02-08-2008, 12:16 PM   #3
I think there is only min considerations for supplies lines... more difficult considerations when it comes to drain pipes....
KUIPORNG is offline   Reply With Quote
Old 02-08-2008, 01:36 PM   #4
How much pressure do you have?
redline is offline   Reply With Quote
Old 02-08-2008, 02:01 PM   #5
I have approximately 60 PSI I think.
Old 02-08-2008, 04:22 PM   #6
Journeyman Plumber
Ron The Plumber's Avatar
The answer is too many fixtures on that 1/2" line.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-08-2008, 04:52 PM   #7
Send a message via AIM to Marlin
By code a half inch line can have a maximum of two fixtures. I also try not to let a shower share a half inch line with any fixture not in the same bathroom. The last part isn't code, just something I like to do.
Marlin is offline   Reply With Quote
Old 02-08-2008, 08:52 PM   #8
Thank You
I will do it the right way, thank you for the advice!
Old 02-08-2008, 10:36 PM   #9
I always run 3/4" hot & cold main lines then 1/2" to last fixture on dead end run with 1/2" branch lines to the other fixtures along the way.
dyier is offline   Reply With Quote
Old 02-11-2008, 10:10 PM   #10
biggles's Avatar
you could run as much as you want off the 1/2" pipe just don't use all of them at one time.the whole house is 1/2" after the meter just don't size up even if you start out into the yard keep it 1/2"..toilets only draw on the water when you flush them so that leaves the sink and showers..if somebody is in the shower and you turn the sink cold on you'll hear it...or them.
Old 02-11-2008, 10:23 PM   #11
Journeyman Plumber
Do it right or not at all.
Biggles not come on here telling others doing things the wrong way is ok.
some branches of my radiator pipe tree not getting warm ? amakarevic Plumbing 7 11-13-2007 09:24 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
