Too Far On Tile Floor Before Installing Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2012, 12:50 AM   #1
Too far on tile floor before installing flange?
I have laid tile in the bathroom and cut out the 4 inch exit pipe coming up through the floor. The tile is a circle around the pipe. I have yet to put the toilet flange in and can set it in directly on top of the floor but how do I secure it to the tile floor. Do I need to drill holes in the tile? Should I have left room around the hole for the pipe to attach the bolts? Afraid I have done too much already.
ElectricNic is offline   Reply With Quote
Old 03-19-2012, 05:13 AM   #2
DIY staff
Rewards Points: 7,174
The flange can be attached to the top of the tile---use a diamond bit to drill the holes--
A hammer drill with a masonry bit might work just fine,but the possibility of cracking a tile exists.
Make sure the new flange is not to thick to clear the neck of the toilet-check before installing.
Old 03-19-2012, 05:46 AM   #3
Rewards Points: 2,516
Buy a tile drill bit like the one pictured. Home depot has them. Made by Bosch. Take some playdough or something similar and make a ring about 2 inches in diameter.
Stick this ring of playdough on the floor centered around where you need to drill a hole. Put a little bit of water on inside the ring of playdough and start drilling.
The water helps keep the bit cool. I used this method and it worked fine.
There is a youtube video showing this
hammerlane is offline   Reply With Quote
Old 03-19-2012, 05:51 AM   #4
here's the video
Hardibacker overlapping or sitting on top of tub tile flange?? (Pics) tunabreath Kitchen & Bath Remodeling 3 08-10-2011 11:39 PM
Im installing 18 by 18 travertine tile for an hearth need some help kat10 Flooring 2 07-27-2011 07:45 AM
Installing Hardwood Floor butting up to tile Macker Flooring 3 01-02-2011 03:21 PM
someone installed tile over my toilet flange! Emergesunscathe Flooring 3 10-13-2010 01:44 PM
Shower tile: Should I affix the tile to the shower base's flange? Swazzle Remodeling 1 10-06-2010 11:39 AM
