Toliet Wax Ring Dilemma - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2009, 10:55 PM   #1
Smile
Two of my toilets have had trouble with flushing so I removed them to find out that the plastic ring inside the "wax ring" was crumpled and bent,which prevents waste from exiting to bottom of the toilet. Since most wax ring kits come with the black plastic cone attached, is this needed? Do I need to trim the cone before installing to toilet? Could the cone be getting smashed as the toilet is set? What can be done to fix this problem?
myworkshop is offline   Reply With Quote
Old 05-04-2009, 11:27 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Just use a wax ring without the cone. That is the way most of them are. I only use the ones with the cone if the top of the flange is set level with the finished floor.
JDC is offline   Reply With Quote
Old 05-05-2009, 07:34 AM   #3
Rewards Points: 150
I agree with jc but the other thing that i do is that i put the wax ring on the toilet rather than the flange on the floor to avoid having it slip on the flange.
al's sewer is offline   Reply With Quote
Old 05-05-2009, 08:52 AM   #4
I never had that problem until last year. Seems that the plastic ring is larger in diameter than necessary. The wax seal would not even set flat on the flange. I ended up cutting the cone with a utility knife since I knew it was going to cause problems.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-05-2009, 10:30 AM   #5
Thank You, I will take your advice and proceed!
Old 05-05-2009, 10:31 AM   #6
Thank You, i will do that in the future!
Old 05-05-2009, 10:32 AM   #7
Thank You, I will do the in the future!
Old 05-05-2009, 10:34 AM   #8
Great advice!Ii will do that on my master bathroom toilet!
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-27-2016 11:52 PM
Removing compression ring? ruzz Plumbing 30 10-01-2011 06:14 PM
rocking chair or toliet? kahnegirl Plumbing 6 01-16-2009 11:29 PM
Ring Main Question Andyjr Electrical 5 09-14-2008 09:47 PM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 09:24 PM
