Toliet Waste Line Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2012, 06:10 AM   #1
Toliet Waste Line issue
My master bathroom was remodeled but the waster line (4") for the toliet has a slope that flows back towards the toliet. I cannot reslope it for the correct slope per foot ratio since the tee is in the wall and cant be moved without tearing up the downstairs bath room. The run for the waste line is short to the stack (less than 24") I know I can't run an S-trap to fix the slope issue since having the trap is against code and could cause blockage issues. I am stuck on how to fix this problem.
elieli31 is offline   Reply With Quote
Old 12-13-2012, 06:53 AM   #2
DIY staff
Rewards Points: 7,174
Either fix the pitch or remove the toilet====I also wonder wnat you are talking about a trap ???? toilet drains do not have traps===Please clarify--
3" is fine for a toilet drain---could you get the pitch you need by removing the 4" drain and converting to 3"??
Inside cutting tools are available to remove the pipe from the T-without damage---
Old 12-13-2012, 07:44 AM   #3
joed's Avatar
Rewards Points: 12,382
Tearing up the wall in the downstairs bathroom sounds like your only option from your description. How much is the slope out? Can you post a picture?
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
Proper gas line installation for wall furnace rsaritzky Plumbing 2 11-20-2010 12:39 AM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Toilet waste line slope? jadrma Plumbing 7 11-10-2008 05:04 PM
