Toliet TAnk Support - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2010, 04:31 PM   #1
Toliet TAnk Support
Had a guy replace current toliet and it now sits about 5 inches from the wall. He says its because I replaced it with a bigger toliet (not round) and that the flange was also cracked. He had to do a quick repair.
Can the tank be supported. Its loose now, and he said not to tighten it down to tight. None of this sound right. help
hcbenton is offline   Reply With Quote
Old 03-09-2010, 04:55 PM   #2
Rewards Points: 352
If it's not tight it's not right. different toilets have different offsets from the wall. Did he move the closet flange when he did the repair? Is the tahk loose or is it the bowl wobbling on the floor?
plumberinlaw is offline   Reply With Quote
Old 03-09-2010, 05:46 PM   #3
Licensed Master Plumber
sounds like you done bought the wrong toilet. They come 10, 12 and 14" rough. Take it off the flange and measure the center of the flange to wall distance and purchase toilet appropriately.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-09-2010, 09:48 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We've noticed that 12" rough pro-flo toilets (from ferguson) sit about 1-1/2" from the wall....
5" is pretty extreme, although it really shouldn't matter too much since they aren't meant to really be leaned against.
We do have a customer who leans on the toilet so heavily we have to continually go and tighten the tank-to-bowl bolts.
Journeyman Plumber
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Building a large Fish Tank - How? darenrogers General DIY Discussions 3 01-20-2010 07:50 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
