Toliet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2011, 12:36 PM   #1
Toliet Flange
With viewing the picture below, will a plumber be able to install a flange/toilet once I've installed all the flooring?
The coupling and new PVC pipe are primed and cemented. I was told by someone that the PVC pipe cannot be cemented prior to installing the flange (but the coupling should be). Is there a work around for this?
kadams2345 is offline   Reply With Quote
Old 11-11-2011, 01:01 PM   #2
DIY staff
Rewards Points: 7,174
Sure you can---it's done all the time---
Old 11-11-2011, 01:03 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You're going to need a step ladder to get to the toilet.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
plumber666 (11-11-2011)
Old 11-11-2011, 04:34 PM   #4
Can someone explain what a plumber will do once the floor is in? Will they use an "inside pipe" cutter then install the flange? I'm definitely a beginner and I'd love to know!
Also, I'll be making the hole in the flooring for the toilet the size of pipe on the flange - is this correct?
Toilet won't be kept that high!
Old 11-11-2011, 04:55 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 924
When you lay the sub floor material down, make the hole large enough to receive the flange hub. The plumber will cut the pipe with an inside cutter.
If that particular flange is the one you'll be using, I'd set and anchor it on top of the backer board. If set on top of the tile it will probably be too tall, makes life hard when setting the toilet.. That flange is awful thick
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (11-11-2011)
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
toliet flange Micki Plumbing 0 11-05-2011 11:03 AM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
