Toliet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2010, 08:53 PM   #1
Toliet Drain
I have a bathroom upstairs want to move it. But where I want to move it to the joists run the wrong way. I would have to cut the joists but I dont want to do that any suggestions. What size does tthe toilet drain have to be?
Kurt1968 is offline   Reply With Quote
Old 01-20-2010, 06:31 AM   #2
Tough situation, you can cut joists, but they must be reinforced, which makes them bigger, and that is what you are trying to avoid. Size depends on local code, length to the main, but is usually 3 or 4".
Old 01-21-2010, 07:53 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
run pipe below joists,drop ceiling or build soffit around it
plummen is offline   Reply With Quote
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
