Toliet Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2009, 11:14 AM   #1
Toliet Connection
I have a leak at the joint where the pipe comes out of the wall and connects to the valve that goes to the toliet. It is the solder joint that is leaking. I am not good at soldering and there is very little room, and it is close to the wall. What other alternatives are there?
jm219412 is offline   Reply With Quote
Old 07-13-2009, 11:20 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
How are you at un-soldering? Heat up the existing stop(valve) and remove. Clean up the end of the copper tubing and install a compression stop. If you have enough pipe sticking out of the wall you could cut it off with a hacksaw and install a compression stop. But it sounds like you are stuck with un-soldering.
rjniles is offline   Reply With Quote
Old 07-13-2009, 11:28 AM   #3
I think I have enough room to cut the pipe to remove the valve, how much pipe do i need for a compression valve?
Old 07-13-2009, 11:45 AM   #4
About 3/4 to 1".
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-13-2009, 11:52 AM   #5
A "Handy Husband"
rjniles's Avatar
Originally Posted by majakdragon View Post
About 3/4 to 1".
That should be enough. Make sure you install the eschusion (s.i.c. - trim ring) before you install the stop. If you do not have the room, install a split eschusion (never could spell that word) after you install the stop
Old 07-13-2009, 12:33 PM   #6
Thanks!
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
bathroom sink drain connection wdrwmn Plumbing 3 03-14-2009 05:39 PM
Which WYE for this new toliet application jrterry1976 Plumbing 13 01-23-2009 09:30 AM
rocking chair or toliet? kahnegirl Plumbing 6 01-17-2009 12:29 AM
Proper Sub-Panel Connection jamiedolan Electrical 12 09-04-2008 11:46 PM
