Toilets Running And I Can't Catch It - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2011, 10:38 PM   #1
Toilets running and I can't catch it
Sorry for the dry humor...
I have a basement toilet that has 1 of the "flush holes" that constantly drains water. I've replaced the fill valve and flapper, thought that solved it but it started draining again not too long after.
I just find it odd that only 1 hole drains, or is that normal?
Any suggestions on what to try next?
thanks!
rsplash40 is offline   Reply With Quote
Old 02-05-2011, 11:08 PM   #2
Experienced
Jackofall1's Avatar
thanks!
It really isn't dry at all......
Remove flapper valve and clean flapper valve seat with scotch brite, sounds like you have buildup on the sealing surface of the FV seat.
Mark
Old 02-06-2011, 08:44 AM   #3
Rewards Points: 530
Ditto on cleaning the mating surfaces at the flapper.
Is it the type with a chain on the flapper? If so, make sure there is enough slack in the chain and it is not binding intermittently.
Old 02-06-2011, 09:32 AM   #4
If you recently replaced the flapper I'm inclined to believe the issue lies in the chain length as well. One of the most common mistakes I see people make is either leaving too much slack in the chain or too little. start trouble shooting there and you'll probably have this fixed in no time.
Cheers,
ChrisFixit
ChrisFixit is offline   Reply With Quote
Old 02-06-2011, 12:52 PM   #5
Rewards Points: 530
May be a simple matter of adjusting the flapper itself on the overflow pipe, if it is adjustable.
Old 02-07-2011, 06:15 AM   #6
Rewards Points: 352
If the hose that goes into the overflow is stuck in to far it can siphon causing your toilet to phantom flush and run continuous
plumberinlaw is offline   Reply With Quote
Old 02-09-2011, 04:16 PM   #7
Thanks for all the replies, I'm not in front of it right now but if my memory is right the flapper is not on a chain. I bought what was recommended by a plumber from Menards, but don't recall a chain, I did it a long time ago and just let it annoy me this long so I don't recall.
I'll try the scotch brite pad trick tonight and see if there is some gunk there.
Old 02-09-2011, 05:57 PM   #8
Rewards Points: 352
If he works at Menards he's not a plumber
Old 02-09-2011, 06:03 PM   #9
Experienced
Jackofall1's Avatar
Nah, tell me it isn't so.
Mark
Old 02-09-2011, 09:29 PM   #10
No, it wasn't a person at menards, it was a plumber, who said go get the floatmaster part as it was the best menards sells, and I'm cheap...
So, it is hooked with a chain but I did not replace the flapper, I cleaned it and it seemed to make it worse...
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 02:19 PM
Shutting of running water make toilets run pete0403 Plumbing 7 01-12-2011 11:07 PM
Carrier Furance will not keep running skadera HVAC 13 01-04-2011 10:10 AM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 09:33 AM
