Toilets Clogging - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2013, 03:44 PM   #1
"You can do anything"-Mom
brockmiera's Avatar
Toilets Clogging
I just got a call from my tenant and she says the toilets have been getting clogged more than usual. They were fine when I lived there before she moved in 2 years ago. Any general thoughts on why this might be occurring.
brockmiera is offline   Reply With Quote
Old 02-06-2013, 04:00 PM   #2
Rewards Points: 13,456
Using a stupid amont of toilet paper, kids dropping things down the toilet, old cast iron pipes, main line is stopped up, septic tank full, leach field failing.
With that little bit of info were going to have to guess.
Old 02-06-2013, 04:04 PM   #3
brockmiera's Avatar
Fair enough. Three level townhome built in 1985. All PVC plumbing. Toilet on the top floor and toilet in the basement bathroom. No septic tank this is on city sewer.
Old 02-06-2013, 04:04 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 562
With all due respect- that's like calling the auto mech. and saying your car won't start.
The Following 4 Users Say Thank You to TheEplumber For This Useful Post:
GBrackins (02-06-2013), Gymschu (02-06-2013), Javiles (02-07-2013), joecaption (02-06-2013)
Old 02-06-2013, 04:08 PM   #5
brockmiera's Avatar
I hear ya. I'm just trying to trouble shoot before I drive the 40 miles up there to either replace the toilets or tell her to hire a roto rooter company because this falls under the maintenance clause in her lease.
Old 02-06-2013, 04:14 PM   #6
Plumber
Rewards Points: 562
Toilets are on multiple floors- I'd suspect they're abusing the toilets. just saying....
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-06-2013, 04:22 PM   #7
brockmiera's Avatar
Ok so it sounds like it is on them then. I'll have them get a roto company out there to snake the drain and see how that works.
Old 02-06-2013, 04:29 PM   #8
Plumber
Rewards Points: 562
If a blockage is downstream of the basement toilet then it would probly be backing up in the shower/tub on the same level. Tenant has no other back up issues?
Old 02-06-2013, 04:56 PM   #9
brockmiera's Avatar
No back up issues but she said she's had to snake the shower drains a few times a month because they are draining slow.
Old 02-06-2013, 06:15 PM   #10
Roofmaster
Rewards Points: 2,172
To say it is on the tenant with the very sparse information you have provided is very premature. How old is the house? What size and material is the soil pipe. Are there mature trees in line with your sewer main? (Roots) Do you have water saver toilets? (Disaster, in my book) More info needed.
Old 02-06-2013, 07:03 PM   #11
brockmiera's Avatar
House was built in 1985
4" PVC Waste Pipe
No Mature tree
No water saver toilets. New ones installed when I bought the place 7 years ago.
Old 02-06-2013, 07:17 PM   #12
Roofmaster
Sounds like a lot of hair is going down the shower drains. Strainers?
Hopefully, no pads going down the toilets.
Old 02-06-2013, 07:34 PM   #13
brockmiera's Avatar
Strainer upstairs but not downstairs. I'll tell them to get some strainer caps for the showers too.
Old 02-07-2013, 07:37 AM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 994
Who ever you call make sure its not roto rooter or the thing broken wont be your toilet!
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-07-2013, 01:37 PM   #15
make sure to take a closet auger with you
Change Wall Hung Toilets to Floor Ones ThirdBirch Plumbing 6 01-09-2013 12:12 PM
Kohler Wellworth Toilets Clogging sweaty Plumbing 1 09-24-2011 01:24 PM
comercial toilets Fordguy1956 Plumbing 1 01-31-2009 08:23 AM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 06:07 AM
Slow drains, clogging toilets Keyo77 Plumbing 10 08-16-2007 11:07 AM
