Toilets Clogged - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2010, 07:17 PM   #1
erb
toilets clogged
House was built in 1941, I'm guessing the toilets are original.
At first they just flushed very slowly, clogged, I unclogged with Drano. But now I'm at the point where it is totally clogged.
I bought a big and small auger. I hit a point where I feel the auger line is folding over itself. I pull it back and start grinding on what I think is the clog. I AM GETTING NOWHERE! I'm about to rip these toilets off and start new. But I'd like to avoid the expenses!
Any suggestions? I can upload detailed pics.
-ps the toilets are full of sh*t, this sux (i wear a respirator)
erb is offline   Reply With Quote
Old 08-16-2010, 07:22 PM   #2
Are any other drains that are close to the floor (shower, tub, floor drain) also backing up? Can you take a 5 gallon bucket, pour it into the toilet, and get a proper flush? If other drains are backing up, time to call a rooter company. Call around, don't get ripped off by book pricing or any other BS. If the bucket down the toilet goes down OK, the jets on the toilets are plugged and you're better off replacing the ancient things. If it's still backing up and an auger won't go thru, take em off, go in the front yard and clear them from the back with the auger or garden hose. And before you put them back really consider replacing them anyways
the_man is offline   Reply With Quote
Old 08-16-2010, 07:42 PM   #3
Owner
LateralConcepts's Avatar
The way you explained everything as plural "toilets", "they", sounds like you have a bigger problem than a clogged toilet. There's most likely a blockage in the main. You need to determine that before anything else. Don't try the bucket of water if they are already full.
How is the house laid out? Upstairs, downstairs, basement, etc.?
Is there water coming up anywhere else? Floor drain, shower, tub?
If this is just one toilet you're talking about:
As the_man said, don't mess around with trying to run an auger through from the top. You could cause a bigger problem. Take the entire water closet off the floor, take it outside, then run your auger from the bottom up. Flush it out with a garden hose, then reset it with a new wax ring. If you can afford to replace the toilet(s) do it.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-16-2010, 07:56 PM   #4
erb
No other drains are clogged or slow.
No, the toilets do not flush.
So I'll just take off the toilets, figure out the clog from there, install new toilets.
Old 08-16-2010, 08:02 PM   #5
Owner
A shop vac will help. Suck the tank and the bowl dry before you remove the toilets.
Still curious why plural, "toilets". More than one simultaneously typically indicates a different problem. Any gurgling or movement in the toilets when you run water elsewhere?
Lateral
(208) 818-8241
Old 08-16-2010, 08:13 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 922
I'm guessing thy're back to back and the auger is coming up the other side
Old 08-16-2010, 08:33 PM   #7
Rewards Points: 1,548
How far did the snake go down before it got stuck?
Old 08-17-2010, 10:03 AM   #8
erb
No gurgling
The snake went down 3ft.
Old 08-17-2010, 09:44 PM   #9
You could remove one of the toilets and then put a bigger snake down.
Do you make any progress if you leave the toilets there for the time being, use your existing snake but as soon as it hits an obstruction, apply less pressure, but keep grinding away down there?
What floor (second, basement, etc.)
always clogged toilets, HELP! clogged_toilets Plumbing 8 04-22-2010 03:09 AM
Talking Toilets! ScottR Off Topic 4 08-11-2009 05:36 AM
comercial toilets Fordguy1956 Plumbing 1 01-31-2009 08:23 AM
Kohler wellworths Clogged Chemist1961 Plumbing 20 01-11-2009 07:43 PM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 06:07 AM
