Old 01-12-2013, 10:32 PM   #1
toilets
all three of my toilets just fill up when I flush them
jennylynn1761 is offline   Reply With Quote
Old 01-12-2013, 11:19 PM   #2
toilets
what part fills up? if the bowl fills up like its gonna overflow you prob have a main line that is clogged. is this a single story house? did they all start doing it at the same time? any small children that are missing toys?
Old 01-12-2013, 11:58 PM   #3
toilets
Septic tank town sewer?
Main lines pluged up, tank is full, or leach field has failed.
I'd start at the clean out.
Old 01-13-2013, 02:06 AM   #4
747
registered
747's Avatar
toilets
Do you have a clean out in the front yard? If yes twist lid off and somebody flush toilet is water moving pass the clean out? If no snake from clean out to house. If yes snake from clean out to main. This is assuming your not on a septic tank. Your best to snake both ways. But this will determine where the main problem in the pipe is.
747 is offline   Reply With Quote
Change Wall Hung Toilets to Floor Ones ThirdBirch Plumbing 6 01-09-2013 01:12 PM
toilets clogged erb Plumbing 8 08-17-2010 10:44 PM
Talking Toilets! ScottR Off Topic 4 08-11-2009 06:36 AM
comercial toilets Fordguy1956 Plumbing 1 01-31-2009 09:23 AM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 07:07 AM
