Old 03-14-2012, 11:04 PM   #1
toilets
I have 2 toilets in my house one flushes just fine the other one has no suction, why?
deekdyll is offline   Reply With Quote
Old 03-15-2012, 12:21 AM   #2
toilets
It could either be a low flow toilet, or if it is in a basement there could be an issue with the pump.
homefixr is offline   Reply With Quote
Old 03-15-2012, 07:19 AM   #3
toilets
Old toilet??? The siphon and flush holes often become clogged with calcium deposits, which slows the flush action over time. Soak it is some CLR to loosen and remove those.
Old 03-16-2012, 01:07 AM   #4
toilets
Is that the same reason that the flappers som.etimes dont seat properly on old toilets and you get the constant tank filling?
toilets clogged erb Plumbing 8 08-17-2010 10:44 PM
Mansfield Toilets? kcrossley2 Plumbing 9 08-23-2009 06:08 PM
Talking Toilets! ScottR Off Topic 4 08-11-2009 06:36 AM
comercial toilets Fordguy1956 Plumbing 1 01-31-2009 09:23 AM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 07:07 AM
