Old 02-02-2013, 08:24 AM   #16
Toilet won't sit all the way on floor
Originally Posted by joecaption View Post
Exactly what I was thinking.
I've seen many an old toilet done like that. Most never had a flange just dowel bolts holding it down.
Of course most of them also had leaked and rotted out the floor.
yes sir, me too. i've seen a lot with no flange. just a makeshift one made out of a piece of lead.
buddy builder is offline   Reply With Quote
Old 02-02-2013, 08:29 AM   #17
oh, and let sit for 24 hours,
Old 02-02-2013, 08:31 AM   #18
oh, and let sit for 24 hours.
Old 02-02-2013, 08:32 AM   #19
You said your stepping in a puddle. I would take the ceiling out and cut the cast iron pipe. If you are not comfortable working off a ladder and cutting overhead then just hire someone. But, be careful.
paintdrying is offline   Reply With Quote
Old 02-02-2013, 08:28 PM   #20
Roofmaster
Yeah, and in the old days, tile was laid in a wet set over green cement that was about 1.5 to 2 inches thick over lath wire, over roofing felt. But that was the old days. These are the new days of peel and stick crapo flooring from you know where. So I guess he should go below, cut out the ceiling, Install a new PVC closet bend attached to his pipe with a fernco, and anchor it to a solid, finished floor, dont you think? That old way of hit or miss with the adjustable wrench sounds like it was a bad idea back then and it still is.
" A lot of men build things, and a lot of things fall down "
Old 02-02-2013, 09:13 PM   #21
Master Plumber
Javiles's Avatar
Originally Posted by plumber666 View Post
When you say "customer", I'm assuming you mean you are being paid to do this work. If you are charging somebody for work you don't know how to do, I'd call you a crook. Since this is a DIY site, asking advice on how to do work you are underqualified to do, not ticketed to do, and not doing for yourself in your own home, I say, "Get lost!!"
Plumber666 its a good thing your not in Miami you'd spend the whole day throwing people out your house
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-02-2013, 10:57 PM   #22
Mr 666 is doing something else, check the date
Old 02-02-2013, 11:38 PM   #23
Master Plumber
Javiles's Avatar
Dam it who keeps bringing these old threads back from the dead, its like talking to yourself.
Old 02-03-2013, 09:29 AM   #24
Originally Posted by Javiles View Post
Damn it who keeps bringing these old threads back from the dead, its like talking to yourself.
Google, Bing, or Yahoo.
I say there is nothing wrong with a plastic (white sheet Plexiglas) cutout of the outline of the toilet bottom to act as a large all around shim, although this may take some time to construct.
A well formed bead of mortar as a large all around shim works well except you can have a chicken and egg problem. The bead needs to fit the toilet accurately (or you need to add additional thin shims plus caulk to fine tune it) before you make the final installation with the wax ring. Whereas the best way to form the shim is to use the toilet itself, but then it is difficult to lift off the toilet for final assembly with the wax ring. I am guessing that the bead should be at least 2 inches wide so if it cracks into little pieces the pieces won't slide around so much that the toilet becomes undermined and loose.
It is of utmost importance that the toilet not rock or wobble during a test fit without the wax ring. Any movement of the toilet after the wax ring is in place will cause immediate failure of the wax ring.
It is of utmost importance that the toilet not touch let alone put weight onto the flange. This can cause the toilet to crack.
Oh, by the way, a DIY site is an excellent way to save face if you run into complications after starting a job (and have time to await a reply). Like lifting off the toilet and only after that finding that the flange is too high. By saving face I do not mean 100% of the time saying, "I'm not qualified so I'll get someone else in to finish or help out."
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
profcolli (02-04-2013)
When tiling a new floor and the floor is unlevel can you still tile it for a toilet? whiz Tiling, ceramics, marble 7 04-22-2010 07:30 PM
Installing toilet on concrete floor diymaniac Plumbing 2 12-14-2009 11:52 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Installing a toilet over harwood floor caglezs Plumbing 5 02-08-2008 12:23 AM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 07:59 PM
