-   -   toilet won't flush properly (http://www.diychatroom.com/f7/toilet-wont-flush-properly-163176/)
slm3324 11-13-2012 06:48 AM
my son replaced the flush system on the toilet now when flushing the water does not empty completely out of the tank and the water does not empty all the way out of the bowl making that swishing sound. I know the toilet is not plugged, i think there is an adjustment to be made but how and where? also how do you see the replies you receive? thanks
jjchips 11-13-2012 07:35 AM
flushing toilet
I was just about to post the same issue, the toilet just makes a swiling motion and nothing empties without plunging the bowl, also makes a sucking sound,
PoleCat 11-13-2012 08:04 AM
The quickest way to see if there may be an obstruction is to dump a large bucket of water all at once into the bowl. If you get a great flush you know you're good in that direction. You also know you are not getting enough water fast enough from the tank into the bowl to get the same results. In my experience this was almost always due to scale build up in the water channel from hard water and time. The fix was about a quart of muratic acid down the overflow tube. Evacuate the room and let it work for about 1/2 an hour then flush out the deposits. Less frequently it would be a flapper valve that needed replaced because it couldn't float very well anymore or one of them flappers with a ballast tube on it that snapped shut too soon because the tank was level enough.
joecaption 11-13-2012 09:32 AM
I'd never suggest anyone use muratic acid in a toilet. Highly toxic and corrosive.
Lift the cove off of the tank and make sure the water coming up to the fill line. There should be a line or even the words "fill line" right on the back side of the tank.
If it is then take a pipe cleaner of metal coat hanger and clean out the holes in the under side of the lip in the toilet.
Still not working? then you may have something stuck in the toilet trap, pluged drain line or vent.
