Toilet Wont Flush All The Way - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2013, 01:45 PM   #16
Roofmaster
Rewards Points: 2,172
I would personally take that 123 whatever the hell it is and recycle it. Install a fluid master, and a normal stand tube and flapper, and never look back. Unfortunately, the new standtube will require removal and re-installation of the tank. Buy a new tank to bowl washer and bolt kit while you are there, and a new SS Braided toilet supply. Take the old tank to bowl doughnut with you so you can match it up.
Happy Flushes to you.
Old 03-22-2013, 04:07 PM   #17
u have hard water as does 90 percent of the country change back to a regular flush kit and youll be fine i recomend flushometer im a licenced plumber by the way
zcs20027 is offline   Reply With Quote
Toilet flush lever problem diyrocks General DIY Discussions 20 12-09-2016 08:12 PM
Old eljer toilet with flush ball (no flapper) leaks cbrc5eric Plumbing 18 04-24-2014 01:51 PM
Toilet Won't Flush schraggyj Plumbing 16 07-23-2011 03:22 AM
Gerber Pressure Toilet does flush all the way jimrens Plumbing 0 05-10-2011 09:10 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
