Toilet Won't Fill Up With Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2012, 03:31 PM   #1
toilet won't fill up with water
Our toilet tank will not fill up with water. The toilet bowl appears to be clogged. What can we do? Barb Cano
Barbara Cano is offline   Reply With Quote
Old 05-06-2012, 04:01 PM   #2
MarginallyQualified
Rewards Points: 2,464
clear the clog.
start with a bucket of water...
then go to a plunger; move up to a closet auger if needed.
After the clog is cleared... look inside the tank for water level.
the float may need to be adjusted upward to allow more water in before it turns off the supply or the float may be faulty or the flapper may be leaking and letting water pass by.
figure out which is YOUR problem.
usually replacing the whole shebang is the best use of time.
http://www.youtube.com/watch?v=Uygnb...feature=relmfu
Old 05-07-2012, 08:47 AM   #3
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
There are two separate issues here.
The toilet appears to be clogged.......... Fill up a bucket of water from another source and gradually pour it into the toilet bowl. If water level starts to rise, stop pouring and use a plunger until clog is cleared. If this fails, the clog may have to be cleared with a rotating snake. If the water level does not rise, your toilet does not have a clog.
The tank will not fill up.........this could be one of a number of things.
Shut off valve turned off
Shut off valve or feed line clogged
Tank float or valve stuck..
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 09:11 AM
