Toilet Won't Fill Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2012, 06:47 PM   #1
toilet won't fill up
What could be the reason why my toilet won't fill back up with water when i flush it?
jayjay20 is offline   Reply With Quote
Old 01-17-2012, 06:55 PM   #2
Rewards Points: 14,312
Take off the tank cover and see if the float, or trip lever is stuck.
Old 01-17-2012, 06:57 PM   #3
jproffer's Avatar
Rewards Points: 716
Stuck fill valve
Bad fill valve
Take the lid off the tank and push down on the float. If the water starts running, it was stuck. If the water doesn't run with the float pushed down, the valve is bad and needs replaced.
jproffer is offline   Reply With Quote
Old 01-17-2012, 08:36 PM   #4
Rewards Points: 582
shut of water take supply line loose turn on slowly see if you have water to valve...if so replace ball cock assy fluidmaster pro or 400a...
Toilet Tank Won't Fill Up with Water hmbrown Plumbing 9 09-14-2011 02:39 PM
Toilet Not Getting Water To Fill Up mdlab Plumbing 3 08-27-2011 05:35 PM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
Toilet leaks? but not really? gunrock Plumbing 3 04-22-2010 05:20 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
