Old 10-24-2009, 09:09 AM   #1
Toilet Won't Fill
My toilet won't fill when I flush it. However, I've noticed that if I turn on the bathtub water right next to it, and then turn it off, the toilet will start filling. Strange. My water pressure is generally good throughout the house.
Any ideas on this one? Bad flex lead coming into the toilet? Bad fill valve? Slow pipes in the walls? The pipes are about 70 years old.
Thanks much,
Adrian
adrian is offline   Reply With Quote
Old 10-24-2009, 11:24 AM   #2
Toilet Won't Fill
Sopunds like you may have some trash in the fill valve or the toilet supply valve. Turn off the water supply valve and disconnect the tube going to the toilet. Hold a rag over the valve and quickly turn it on and off a couple times. This should clear the valve. I would change out the fill valve since for under $10 you can install a Fluidmaster 400A valve. The trash may be bolcking the flow of water until you use another fixture (tub) and the trash "relaxes" some, allowing water to flow past it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-24-2009, 11:47 AM   #3
Toilet Won't Fill
Replacing the fill valve did the trick! It's operating normally again.
Tags
plumbing, toilets
My Toilet Tank won't fill up! Toilet Humor Plumbing 8 08-19-2011 11:18 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
replace toilet fill valve jmauro1964 Plumbing 7 09-26-2009 01:04 AM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 10:37 PM
Broken toilet fill valve npac Plumbing 7 08-04-2009 11:26 PM
