Old 04-22-2012, 08:58 PM   #1
Unhappy
toilet won't fill
I have the most damning of toilets. I have replaced guts 3 times with fluidmaster and they work for a while and stop filling and flushing. So here it's happening again. 3 Toilets are 15 yrs old but not much use since kids left. Any help would be appreciated.
jonispicer is offline   Reply With Quote
Old 04-22-2012, 11:33 PM   #2
toilet won't fill
Old steel pipes in the house?
Old 04-23-2012, 06:25 AM   #3
toilet won't fill
Not much info to go on. fill valves have nothing to do with the flushing action of a toilet accept for making sure the tank is full. it could be a mineral buildup in the passeges in the toilet bowl. Are you adjusting them properly for fill height? How is the hardness in your water?
danpik is offline   Reply With Quote
Old 04-23-2012, 10:47 AM   #4
toilet won't fill
Pipes are pvc, I think since the home is 15 yrs old. I'm on town water which is softer than than the well water I had. If it is minerals, how do I get rid of mineral buildup. There are mineral stains in the toilets. Thank you so much.
Old 04-23-2012, 10:56 AM   #5
toilet won't fill
Water softner
Old 04-23-2012, 11:14 AM   #6
Lightfoot's Avatar
toilet won't fill
fluidmasters have a small black rubber disc in the top. after a few years, they can become hard and brittle, and either work very slowly or not at all. Shut the water off, take the small plastic top cover off of the fluidmaster, turn the arm assembly 1/4 turn to the left, lift it off, and take the disc out of the top of the fluidmaster, flush the crud out by holding a cup over top of the fluidmaster and turning the water on for a few seconds while the disc is out. then turn water back off, install the new disc in place and re-assemble. The discs are only a buck or two, and you don't even need tools to do this. That would be the first thing i would try.
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Homerepairguy (04-23-2012)
how to fill in the toilet drain and how to cover it?? firsttimediyer Plumbing 1 02-09-2012 06:38 PM
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 08:03 AM
Help with stink coming from Toilet area. Integraoligist General Discussion 9 11-16-2011 06:16 PM
Toilet Tank Won't Fill Up with Water hmbrown Plumbing 9 09-14-2011 03:39 PM
Toilet Not Getting Water To Fill Up mdlab Plumbing 3 08-27-2011 06:35 PM
