Toilet Won't Fill - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2011, 03:02 PM   #1
toilet won't fill
My toilet won't fill up after I flush it, but if I turn the valve that is outside the toilet (chrome), that lets water into the toilet, all the way off and all the way on, it fills.
jclausi is offline   Reply With Quote
Old 08-14-2011, 03:51 PM   #2
Lightfoot's Avatar
Rewards Points: 272
likely a faulty fill valve.
if it's a fluidmaster, just replace the little rubber diaphragm (bout 2 bucks).
While you've got it apart, flush the line to make sure there's no crud blocking the flow.
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
plumberinlaw (08-14-2011)
Old 08-14-2011, 05:09 PM   #3
I'm not sure what a fill valve is
Old 08-14-2011, 05:33 PM   #4
DIY staff
Rewards Points: 7,174
Lift off the top of the tank---there is a tall thing with a float toilet fill valve - Google Search
That is faulty----a new one costs $10 or so and takes 15 minutes to install---the old one could be repaired also.
The diaphragm is sticking and changing the pressure by turning on and off the shut off is freeing it up temporarily.
Old 08-14-2011, 05:41 PM   #5
Experienced
Jackofall1's Avatar
Sounds more like an isolation valve (the chrome one), chances are the seal has torn away from the stem and is causing a blockage in the line, when you turn it off and then back on it moves for a bit and then settles back into blocking the line.
mark
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
whistling toilet tank fill problem Need Advice Plumbing 6 01-16-2011 08:13 PM
Slow filing toilet, fill valve already replaced SupraTT Plumbing 4 12-24-2010 06:52 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
