Toilet Wobble - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2012, 04:54 PM   #1
toilet wobble
I have a fairly simple problem I have a toilet that has a wobble. I put a new toilet in with a new wax ring and when placing it it seemed to bottom out and still have the wobble, I left the old wax ring on and added the new I was thinking the floor is off. I kept tightening it and new I had to stop due to cracking. I did tile the floor also. what is the best way to correct it.
GRed is offline   Reply With Quote
Old 07-08-2012, 05:12 PM   #2
DIY staff
Rewards Points: 7,174
Plastic toilet wedges---
No wobble---ever---reset toilet with a fresh wax ring snug down the bolts--add wedges where needed'
Finish tightening bolts--trim off the shims and use silicone caulk to make sire they stay where they are.
Old 07-08-2012, 05:31 PM   #3
Post
Toilet Wobble
Cool Thanks... also should I silicone all the way around it. I thought doing that was a no no
Old 07-08-2012, 05:38 PM   #4
DIY staff
I avoid that too--just a dab will do to hold the shim.
Just a note--code in some areas actually requires a toilet to be caulked to the floor---some times I don't understand the code writers--
Old 07-08-2012, 06:30 PM   #5
Toilet wobble
Ok, just a dab. Good to know. Another question..do you think I should leave the new wax ring there and maybe add another or slice a new one or remove the new old one which is since jan. I put that on.
I appreciate the help..
Old 07-08-2012, 06:52 PM   #6
DIY staff
I'd replace the existing one---they are cheap--and I have seen over done wax that squished onto the pipe and caused a flow problem--
Also when the toilet is off--check these two things.
Feel the bottom for bumps--some times a glob of glaze will cause a wobble.
Look at the wax ring--did the toilet bottom out on a high flange?
Good luck--Mike---
Old 07-08-2012, 07:00 PM   #7
Toilet wobble
Really really good to know
Thanks once again for all your advise and help
The Following User Says Thank You to GRed For This Useful Post:
oh'mike (07-08-2012)
Old 07-08-2012, 08:49 PM   #8
Rewards Points: 14,026
Double check that the bottom of the toilet flange is making full contact with the floor.
If you changed the flooring and did not cut the pipe below the floor to make it shorter to make up for a thinner flooring then that flange is going to be to high. It needs to be flush with the finshed flooring or below not a space under it.
Old 07-08-2012, 09:17 PM   #9
Toilet wobble
I actually tiled the floor so that lowered it. I think it's the floor that's uneven from the back to the front.
Old 07-08-2012, 09:51 PM   #10
To late now to fix it, just shim like Mike suggested.
oh'mike (07-09-2012)
Old 07-08-2012, 10:22 PM   #11
Toilet wobble
Yea I know .
Thanks for all the help I appreciate it
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
