Toilet Will Not Flush - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2011, 07:03 PM   #1
Toilet will not flush
When flushed, the water backs up, as if clogged. When plunged, the bowl will eventually drain. sometimes this happens immediately, sometimes it takes a while for the water to go down and then the bowl is almost empty. if i have not used it for a while (say, after vacation), it will sometimes flush normally.
I live in a basement apartment and there is a 'holding tank' of sorts beneath the toilet that is pumped up and out. the tank also holds water from my shower. it seems to be working.
any tips would be greatly appreciated. thank you
juliet23 is offline   Reply With Quote
Old 09-24-2011, 07:12 PM   #2
DIY staff
Rewards Points: 7,174
Have you tried a plunger yet? Or used a snake? Sounds like the toilet is clogged.
Old 09-24-2011, 07:14 PM   #3
Lightfoot's Avatar
Rewards Points: 272
if you live in an apartment, i'm thinking you rent?
i believe i'd call the landlord, but that's just me.
really, by trying to fix it (beyond plunging as Mike suggested) you could actually make it worse.
Lightfoot is offline   Reply With Quote
Old 09-24-2011, 10:44 PM   #4
Plumb or Die!
Sounds like a macerating toilet system. Sani-Flush? Does the pump come on as soon as you flush?
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
Alan (09-25-2011)
Toilet flush lever problem diyrocks General DIY Discussions 20 12-09-2016 08:12 PM
Toilet Won't Flush schraggyj Plumbing 16 07-23-2011 03:22 AM
Gerber Pressure Toilet does flush all the way jimrens Plumbing 0 05-10-2011 09:10 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
