Toilet: Why Did Someone Sweat The Mounting Bolts To Closet Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2012, 09:11 PM   #31
DIY staff
Rewards Points: 7,174
Sounds like your main shut off valve might not be shutting off completely---if the shut off works there should be no water dripping after the pipes are drained.
Another good reason to use the compression valve--sweat fitting are a nightmare when there is water in the system---
Old 06-04-2012, 11:33 AM   #32
Turn on outside faucet and that stopped the water dripping.
cut off sweated pipe and used compression. the new value is leaking water when I turned water back on. How can I stop the leaks. I don't want to tighten nut anymore.
Did ream copper after cut, is there anything else I can do to stop water leaking out?
kcmasterpiece is offline   Reply With Quote
Old 06-04-2012, 11:37 AM   #33
DIY staff
Did you use the brass Ferrel?
If so then tighten it up more--or un screw the valve and take a oicture and show us what's going on.
Old 06-04-2012, 12:18 PM   #34
I used a brass ferrel. I did tighten it up and it still leaked when the water was turned back on. Here is the picture.
https://picasaweb.google.com/1064090...32340363389986
https://picasaweb.google.com/1064090...98/June4201202
Old 06-04-2012, 01:45 PM   #35
Plumber
TheEplumber's Avatar
Rewards Points: 684
Bad links- says page not found.
Is the 1/2" pipe leaking or the supply line?
Did you clean the copper stub before before adding the ferrel?
Did it seat all the way on the pipe?
Old 06-04-2012, 01:50 PM   #36
I didn't clean it. Should I use brasso. I went back and tighten it and that helped alot. Now, I'm getting a slow drip. I saw water on the floor after 30 min.
Old 06-04-2012, 01:55 PM   #37
Plumber
Rewards Points: 684
As a rule, the pipe I clean any paint, texture, etc. when using a compression nut
Turn off water and drain again. Remove the valve but leave the nut and ferrel on. Apply some teflon pipe dope to the ferrel surface and dope the male threads of the valve-- reassemble. This usually cures small drips
Old 06-04-2012, 02:22 PM   #38
I'm tightening the nuts more and checking in 30 mins. If that doesn't work then I try the Teflon pipe dope (what is that?).
Old 06-04-2012, 02:36 PM   #39
Plumber
Rewards Points: 684
Here's one type (click link)
Old 06-04-2012, 07:56 PM   #40
Thanks everyone one for you advise. Project is done. 2 of the valves are now compression. The 3rd had a drip I couldn't stop. Ended up sweating on the last valve.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Toilet flange "too tall" John_W Plumbing 23 04-29-2012 05:20 PM
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Cracked Toilet Flange BLAKE1982 Plumbing 1 01-11-2009 05:31 PM
