Toilet: Why Did Someone Sweat The Mounting Bolts To Closet Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2012, 09:07 AM   #16
DIY staff
Rewards Points: 7,174
I just don't use them at all (unless they are attached to the faucet---
From these flex lines,I have repaired a flooded new basement job--carpet--trim and doors--24" of drywall--
a complete new kitchen---hardwood floors and cabinets--
A 1500 sf maple floor and all drywall in the 2000 square foot basement--and doors and trim--
So I just don't use them--I don't want that risk or responsibility.
I realize they seldom fail--but when they do,especially in an unoccupied house,the costs are great.
Old 06-03-2012, 10:06 AM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 564
Originally Posted by oh'mike View Post
I always use ridged chrome lines---the flexible ones don't look very professional in my opinion.
And I have seen them fail on many occasions-(with very expensive damage)-I just don't trust flex lines.
I agree with you Mike. People say they don't fail and thats why they use them. But in reality what they're saying is I can't figure out how to bend supply lines properly so I'll use something simple. Same goes for water heater flex lines. My trade is getting dummy'd down....
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-03-2012)
Old 06-03-2012, 05:04 PM   #18
Thanks for all the advise everyone. I just removed the solder with a torch and the bolts slid right out. Now I'm looking at how to remove and replace the water supply valve.
kcmasterpiece is offline   Reply With Quote
Old 06-03-2012, 05:15 PM   #19
DIY staff
Describe what you have or post a picture---Mike---
Old 06-03-2012, 05:41 PM   #20
Here is a picture of the water supply valve that I'm trying to replace:
https://picasaweb.google.com/1064090...crapbookPhotos
What steps would you recommend?
Old 06-03-2012, 05:45 PM   #21
Rewards Points: 528
Heat it up on the pipe side. it is sweated on.
framer52 is offline   Reply With Quote
Old 06-03-2012, 05:48 PM   #22
DIY staff
That is sweated on---but the copper pipe is long enough to use a compression stop valve.
You need a tubing cutter and 2 crescent wrenches.
And an angled stop valve--5/8" (1'2" nominal compression to 3/8"
Cut the pipe right behind the valve--slip on the nut --add the brass Ferrel--screw on the valve--tighten up the compression nut.
If you forgot to turn off the water to the house before doing the above steps--mop the place.
Old 06-03-2012, 06:03 PM   #23
I want to replace the valve with a 1/4 valve that has been sweated on. What is the stuff is the pic and how do I use it to sweat on the new valve.
https://picasaweb.google.com/1064090...49746613555730
I did go outside and turn the water off.
Old 06-03-2012, 06:26 PM   #24
DIY staff
To sweat on the valve--you need a propane or Mapp torch--some flux--red tin of oateys--and some plumbing solder--remove the old valve--clean and flux the pipe--flux the valve--heat with the torch until the solder flows around the opening.
I do suggest the compression fitting--faster--easier and makes replacing or repositioning the valve a snap--
Old 06-03-2012, 06:28 PM   #25
Ok...I'm heading to home depot to get the compression valve.
The Following User Says Thank You to kcmasterpiece For This Useful Post:
Old 06-03-2012, 06:59 PM   #26
I've turned off the main water valve. But why am I till getting pressure/water from the water supply valve that I'm trying to replace?
Old 06-03-2012, 07:02 PM   #27
DIY staff
Did you open up all of the sinks in the house to drain out the pipes?
Old 06-03-2012, 07:05 PM   #28
No but I'm doing that now.
Old 06-03-2012, 07:39 PM   #29
Open up a cold water line that is lower than the supply line you're trying to replace.
VIPlumber is offline   Reply With Quote
Old 06-03-2012, 08:26 PM   #30
I keep forgetting this isn't a perfect world. I seriously thought that I would get ZERO pressure. I opened the other lines in the house which reduced the supply to drips.
Don't know why but I though it would be nothing coming out.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Toilet flange "too tall" John_W Plumbing 23 04-29-2012 05:20 PM
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Cracked Toilet Flange BLAKE1982 Plumbing 1 01-11-2009 05:31 PM
