Toilet Wax Rings - Plain Wax? Reinforced? With/without Flange? How Do You Decide? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 12:10 AM   #1
Rewards Points: 152
Toilet wax rings - plain wax? reinforced? with/without flange? How do you decide?
I added ceramic tile to my bathroom floor so added roughly 3/8" height. I bought a plain round flange (7/16" thick) at Home Depot & used silicon to glue it to the existing flange. Will screw in with slightly longer screws than was used previously.
Question on screws:
HD guy said any screws would be ok - is this true? There were drywall screws in there when I took it apart. Should I use brass (I assume not as strong but won't rust) or just plain old screws (is drywall ok? Or get the silver-colored ones at hardware?)
Question on wax rings: What's the rule on deciding what to use? I went with the flange, thinking it would give me a little extra protection (even though I added only 7/16", if it helps prevent any leakage, I'd be happy) and a "reinforced" ring. Is this a good choice?
Harveys, the Original No-Seep No. 3 Part No. 004305
http://www.plumbersurplus.com/Prod/W...66462/Cat/1372
Secondary question (still in the bathroom!):
I bought a "quick install" faucet which ended up not working out (no room for pop-up lever behind faucet). However, I have a question: they used a soft foam round thing (called a "sponge washer" by the manufacturer) under the part of the drain you see inside the sink. I only dry-installed everything before figuring the faucet would not work, but I was wonder about this soft foam washerand whether I should use plumber's putty instead. For future reference: what do people think of this soft foam washer? (I'm sure it's the same stuff kids use to cut up and glue for art projects). My thought was that bathroom drain chemicals were going to destroy it - possibly dissolve it. (I don't use those things but someone might if I move.) It was an American Standard faucet, seen here: http://www.americanstandard-us.com/p...l.aspx?id=3052
lazzlazz is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
