Toilet Wax Ring Replcement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2008, 07:18 PM   #1
Rewards Points: 101
Tomorrow I'm going to replace the wax ring on my toilet. I have to go to HD to pick up a new ring. Any other supplies I'll need or should expect to find when I take apart the toilet?
Also there is currently grout around the base of the toilet. Can I just replace it with caulk?
jte1130 is offline   Reply With Quote
Old 02-15-2008, 07:22 PM   #2
i think its a personal preference for the grout or caulk you might need new bolts in case they are frozen and you have to cut them with a hack saw
PSHome is offline   Reply With Quote
Old 02-15-2008, 07:46 PM   #3
Handyman
Rewards Points: 512
I agree with PS..pick up some flange bolts. Measure the existing ones first though...nothing worse than flange bolts that are 3" higher than you need!
canadaclub is offline   Reply With Quote
Old 02-16-2008, 01:08 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
A set of brass flange bolts can easily be cut off with a hacksaw blade after initial installation above the nut.
If your floor isn't level around your toilet, you may need some beveled plastic shims made for the purpose to level the toilet before snugging down the bolts. Put a level across the bowl to find out.
Do NOT over-tighten toilet bolts as you may easily crack porcelain. Just snug them down so that the toilet cannot move at all.
Use an anti-mildew tub-and-tile caulk to seal around the front and sides only of the toilet base. Leave the back open for easier early leak detection.
Scrape all of the old wax ring off with a putty knife and wipe off any residue with paper towels. Set the ring on the flange.
Hold the new bolts in place and upright on the sides (at 3 and 9 o'clock) of the flange with bits of the old wax ring or with the old nuts run all the way down. Some people use straws stuck onto the bolts to help guide lowering the toilet. I've never used straws, but do whatever works for you.
Lower the toilet straight down onto the bolts and sit or stand on the toilet to wiggle it down firmly onto the new wax ring.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-16-2008, 06:27 AM   #5
bofusmosby's Avatar
One trick I have used to hold the bolts straight is to use an old coffee can lid, cut it washer size, then cut it in the middle, and slide the plastic "washer" you made all the way down to be base of the bolt. This should hold the bolt straight.
bofusmosby is offline   Reply With Quote
Old 02-16-2008, 09:44 AM   #6
Res Ipsa Loquitur
I recently bought replacement bolts that did have plastic washers to hold the bolts in place. I think they were the 3/8 thick hold-down bolts. I prefer these to the 1/4" bolts often packed in combination kits.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-18-2008, 08:44 AM   #7
Rewards Points: 101
Ok, I did the replacement yesterday. I haven't regrouted or caulked the bottom yet because I want to make sure there is no leakage. Knock on wood everything seems good.
The only problem I have is right at the shutoff valve. There is a tiny leak right at the nut.
Old 02-18-2008, 08:52 AM   #8
Long-Time DIYer
Assuming that the shut-off valve is a compression fitting, the brass ring ferrule is what seals it, not the threads.
Turn the water off and either wrap a wrap of teflon tape or smear a little silicone or pipe compound on the ferrule itself and tighten it back up.
Good Luck!
Mike
Old 02-18-2008, 10:31 AM   #9
Knucklez's Avatar
Rewards Points: 942
don't caulk all the way around the toilet. leave a bit of a gap near the back so that if water does leak a few years later it will escape and you will notice it.
best instructions i have found for toilet install is found here
http://www.hammerzone.com/archives/b..._1/install.htm
Knucklez is offline   Reply With Quote
Old 02-18-2008, 01:03 PM   #10
Rewards Points: 101
It is a brass compression fitting. I'll give that a try. Thanks Mike.
Old 02-19-2008, 11:27 AM   #11
Thumbs up
first you should install your bolts with a washer and nut onto the flange itself, that way they don't wiggle and turn ever again. after you place the toilet on top of the flange just snug it down. AND i never caulk or seal around the toilet because you'll never know it leaks until it's too late and your floor is ruined. even if you leave a little opening in the caulk seal, it might not show right away which is what you want in the first place.
remodeling joe is offline   Reply With Quote
Old 02-19-2008, 05:09 PM   #12
teflon tape or liquid teflon
1. Does liquid teflon dry? If so, how does it take?
2. Can one turn water on immediately after applying?
3. Can one applly liquid teflon to pvc to pvc, and will it hold high pressure?
4. Liquid seems easier than teflon tape--any disadvantges?
--Scott
Last edited by Ron The Plumber; 02-19-2008 at 05:41 PM. Reason: Removed links to web sites, permission is need to post those web links.
24hourapartments is offline   Reply With Quote
Old 02-19-2008, 07:20 PM   #13
liquid teflon stays wet, and yes you can turn the water on right after.
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-27-2016 11:52 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
