Toilet Wax Ring - Oversized For Application? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2011, 06:27 AM   #1
Cape Cod, MA
Rewards Points: 81
Toilet wax ring - oversized for application?
Hey guys. I just renovated my master bedroom and attached half bath. Im continuing the hardwood flooring into the bathroom. My question is, since the hardwood sits higher than the tile previously installed, im going to need a thicker wax ring, is this correct?
How will I go about finding out or measuring which ring i will need?
Thanks!
capecodder is offline   Reply With Quote
Old 11-10-2011, 06:55 AM   #2
DIY staff
Rewards Points: 7,174
Best to add a flange extender ring on top of the old flange in this situation---3/4" rise is a lot -- stacking up double rings could be done but is risky.
Sometimes the stack will shift as the toilet is installed--either blocking the drain a bit or leaking under your nice new wood floor.
Old 11-10-2011, 12:22 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Does the flange now sit above or below the new floor? By how much?
Old 11-10-2011, 02:10 PM   #4
Cape Cod, MA
Rewards Points: 81
Im at work right now but I will measure it when I get in. I was at a plumbing warehouse a while back. I could have sworn they sold thicker wax rings?
Thanks!
Old 11-10-2011, 05:49 PM   #5
DIY staff
They make thick ones---but if you added 3/4" solid hardwood --in my opinion you will be safer adding a flange extender---
Old 11-10-2011, 06:42 PM   #6
Cape Cod, MA
Rewards Points: 81
My hardwood flooring sits 1/4" higher than the metal flange that is bolted to the subflooring. I did a google search for toilet flange extenders. It appears this is a plastic shim of sorts that will sit on top of my current flange? Can this be bought at a home depot or lowes? or will i need to go to a plumbers supply house?
Thanks,
Aaron
Old 11-10-2011, 06:50 PM   #7
DIY staff
If your floor is only 1/4" above the top of the flange --forget what I said about the plastic extender---Just get a wax extender ring or a Jumbo wax ring and you will be fine---
Old 11-10-2011, 07:00 PM   #8
Cape Cod, MA
Rewards Points: 81
Great! Thanks Mike.
The Following User Says Thank You to capecodder For This Useful Post:
oh'mike (11-10-2011)
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
