Old 07-19-2008, 08:04 PM   #1
Toilet Wax Ring & Horn
I'm trying to help a brother finish a bathroom that a contractor left undone. The toilet will not set back in place properly.
The horn of the new wax ring will not drop into the floor flange. It seems the new pvc flange is about an 1/8th inch smaller than standard--small enough that the horn won't go inside it.
My questions are can I just set the toilet on a wax ring without a horn? Can you buy them this way? OR can buy a wax ring with a smaller diameter horn?
(We did try setting the toilet with a standard wax ring and horn combo, but the toilet leaked, and when we removed it the horn was mangled.)
capt2 is offline   Reply With Quote
Old 07-19-2008, 09:42 PM   #2
Whatamess
You can use a ring with out a horn.They are cheaper and work fine.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-19-2008, 10:24 PM   #3
Install just a plain wax seal with no horn. I ran into this once. It seems the pipes inside diameter was too small to accept the horn. Not sure why though.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
Toilet Wax Ring Replcement jte1130 Plumbing 12 02-19-2008 08:20 PM
Disaster strikes...Broken Toilet HORN! J187 Plumbing 13 07-25-2006 10:10 AM
