Toilet Water Supply- Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2008, 11:53 AM   #1
Toilet water Supply- Shut off valve
I am tiling the bathroom floor and having difficulty when it comes to working around the water supply for toilet. The water supply is coming from the floor and there is not enough space to add tile between subfloor and shut off valve. I am aware I can shut off the main water supply and make changes to shut off valve but I am not up to speed on what my options are. Is there some type of pipe extension i can use to move up the shut off valve?
Thanks for any reply.
kcreds is offline   Reply With Quote
Old 04-06-2008, 01:20 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What type of pipe does this shut off connect to?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-06-2008, 01:44 PM   #3
I have attached pics hoping that it will help. I am going from laminate to tile. The shutoff valve is installed right above the piece that covers up the hole in the floor so there is no extra room.
Old 04-06-2008, 02:45 PM   #4
Journeyman Plumber
It's compression, to extend it you will not to access the pipe below the floor line, cut and replace part of it.
Old 04-07-2008, 10:15 AM   #5
Rewards Points: 150
Here is a dumb idea,,,shut water off,take off supply risor above valve ,,,often the pipes below the floor may give a bit(even 'tie' it up if you can),,,if so put tile down let pipe back down,,,IF solid risor is too long shorten it or get a poly supply risor and cut to proper length..IF it doesnt raise up enough for you,you arent any worse off than you were to start with!!
justdon is offline   Reply With Quote
Old 04-07-2008, 12:44 PM   #6
Crabby Bastard
terri_and_jj's Avatar
is this a first floor or second floor bath?
terri_and_jj is offline   Reply With Quote
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Water Valve won't shut off armywife Plumbing 1 12-17-2007 05:16 AM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 03:58 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
