Toilet Water Supply - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2012, 10:43 PM   #1
Toilet water supply
My question is...is it OK to rough in the water supply to the toilet on the right side , to hide it in the corner of the bathroom even though the hook up is on the left side?
KShirriff is offline   Reply With Quote
Old 11-08-2012, 10:46 PM   #2
Rewards Points: 582
why would you want too....its normal to see valve and supply.....even in 300-400,000 homes..ben
Old 11-08-2012, 10:55 PM   #3
Rewards Points: 12,858
And then what, have a 3' supply line showing?
Old 11-08-2012, 10:57 PM   #4
OK I get the point... I just thought that maybe the supply valve might be more ugly to see.
Old 11-08-2012, 10:59 PM   #5
Thanks...Sometimes I try to complicate things.
The Following User Says Thank You to KShirriff For This Useful Post:
ben's plumbing (11-09-2012)
Old 11-08-2012, 11:01 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 352
Put the magazine rack in front of it
Old 11-08-2012, 11:13 PM   #7
LOL... I here you.
Old 11-09-2012, 07:30 AM   #8
Rewards Points: 582
LOL... I here you.
make it gold plated..then it looks like your richben
leaks on rear base of toilet & water supply valve Nospammer Plumbing 1 08-16-2012 04:21 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 10:48 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Hot Water Toilet GeauxCajuns82 Plumbing 1 10-10-2008 10:21 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
