Toilet Water Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2011, 08:37 AM   #1
My tenant is having a problem with a toilet. When I went to turn the water off I found a shut off valve that I have never seen before. The valve is plastic and has a knob but it doesn't matter which way you turn the knob it does not stop the flow of water. Pushing or pulling on the knob does not work either. Can you help me out with what kind of shut off valve it is and perhaps let me know how it operates.
anelson is offline   Reply With Quote
Old 07-11-2011, 09:42 AM   #2
DIY staff
Rewards Points: 7,174
Is it a cheap thing with a water line built in?
I've run into those from the 1980s---I never could get one to work. I just change them out---
Good luck removing the old one--I could not find a way to release the push on fitting so I either cut the pipe if it's long enough or split the plastic collar.
Water valve will not shut off smcpherson Appliances 2 05-18-2011 09:55 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
