Toilet Waste Off Set - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2012, 07:52 PM   #1
toilet waste off set
how to off set sewerage wast from toilet that is now 25mm too high after tiling floor. waste outlet is old caste iron flared flange
gjlj.kelly is offline   Reply With Quote
Old 08-10-2012, 08:02 PM   #2
Rewards Points: 13,228
Are you saying the finished floor is higher then the flange by 25mm? Or is the flange now 25mm higher then the floor?
How in the world did it end up by being almost an 1" differant?
PS All most everyone on this site does not use the metric system.
Old 08-10-2012, 08:19 PM   #3
Unhappy
off set toilet
long story mate, old house, dodgy re stumping job by previous owner, 7mm tile underlay plus tile glue and 10mm tile. it's probably 22mm to be exact. but the problem I have is the inlet id=s the old flared out flange that appaerently is not compatable with poly pipe. It has an elbow in it to the right which goes out the external wall. Oh yeah and it's second story toilet as well. I can pull off weather boards and try and get in there with an angle gringer and cut out the iron pipe but, man what a pain in the a#*&. sugestions?
Old 08-10-2012, 08:24 PM   #4
Did I explain that the outlet is tiled into a boxed area that I can only get at by removing weatherboards? It comes in from the right hand side, sharp bend then into the toilet. It was covered over to hide the ugly iron pipe
Old 08-10-2012, 09:36 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 436
Where do you live anyways?
Your description sounds foreign to me
Can you post a picture of what you got going on?
Old 08-10-2012, 11:30 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Dodgy.... re-stumping..... metric measurements. What was your first clue?
I second the request for pictures, and would love to see pictures from below as well.
Journeyman Plumber
Old 08-10-2012, 11:34 PM   #7
Plumber
Rewards Points: 436
Well mate, he didn't say loo....
Old 08-10-2012, 11:48 PM   #8
My money's on Oz.
VIPlumber is offline   Reply With Quote
Old 08-13-2012, 06:51 PM   #9
Smile
offset toilet outlet
yes, I'm from Australia. Victoria actually. And yes we are metric down here. And yes we got our arses kicked in the pool in London but lets not open up that wound. But I've got problems with my own "crap" in the water". I will try and post a photo. My problem in short is the toilet pan waste outlet is 7/8 inch to high. /Users/glenn kelly/Pictures/iPhoto Library/Originals/2012/14:08:2012/Photo on 2012-08-14 at 11.35.jpg
Old 08-13-2012, 09:44 PM   #10
toilet offset
I have attempted to attach a photo. if you cant open it can you ket me know how to attach one.
Old 08-13-2012, 09:59 PM   #11
Plumber
Rewards Points: 436
no go, mate
How to attach a photo to a post
Old 08-13-2012, 09:59 PM   #12
Doing it myself
Alan's Avatar
It didn't work. Someone around here has a link to the thread where they show how to post photos. I think Ohmike has it.
Journeyman Plumber
Can you connect a shower waste pipe to toilet waste? microbar Plumbing 15 05-18-2011 03:59 AM
Shower waste pipe to toilet waste microbar Plumbing 2 05-17-2011 05:24 PM
Waste from other toilet? scottl31 Plumbing 22 11-18-2010 03:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
