Old 10-15-2009, 10:11 PM   #1
Default Toilet Waste Line Running Sideways ...
my wife has convinced me to convert the 4th bedroom in our house into an ensuite ... only problem is that now places a bathroom in the back corner of the second story of our house - where the sewage lines are in the middle of the front and back of the house.
so my question is, how far can / should I run a toilet waste line sideways - to get the sewage line from the corner of our house to the middle of the house?
can / should this even be done? - I assume I should have a 'slope' to the line - but what's an effective rise/run for a toilet waste line?
hopefully this makes sense ... otherwise, here's an attempt at a picture...
________________________________
| X---------------O-----------------|
| ----------------O-----------------|
where X is the toilet location on the second floor
and O is the sewage drain location in the basement
(nevermind the "-" needed to have something there for the spaces).
any info would be greatly appreciated!
njchan is offline   Reply With Quote
Old 10-15-2009, 10:50 PM   #2
Master Plumber/Mechanical
For a toilet you can run a 3" line the fall the the line is 1/4" per ft also you need to install a vant for this drain
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-16-2009, 06:31 PM   #3
nice ...
thanks for the info.
do toilet lines normally have vents?
Old 10-16-2009, 07:33 PM   #4
yes all fixtures should have a vent or aav.
What have I done is offline   Reply With Quote
Old 10-16-2009, 07:44 PM   #5
Yes toilet have vents. What every you do DO NOT USE AN AAV.
An AAV is not worth the hassel..wish they were never created and some code no not allow them
Old 10-19-2009, 01:16 PM   #6
Not necessarily. The applicable code where I live is IRC 2003, which does not require toilets to be vented. I just had my plumbing put in by a licensed plumber, and he did not vent the toilets.
Old 10-19-2009, 01:56 PM   #7
All fixtures require venting.
And how far away from the stack is your toilet?
I would also bet that your toilet is vented and if is not then even under IPC 2003 it is not meeting code. The IRC (International Residental Code 2003) and the IPC (International Plumbing Code 2003) states it must be vented by either distance from rhe stack or if over legal distance then by an individual vent.
By the sound of this mans install it is going to be far away from the stack and will need vented
Old 10-19-2009, 08:48 PM   #8
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Talking Adding 2nd floor bathroom ?
YES YOU ARE SO CORRECT WHERE YOU LIVE THEY DON'T NEED VENTS BUT
THAT IS BECAUSE OF 30 PLUS YEARS IN PLUMBING
I HAVE NEVER EVER SEEN A "OUTHOUSE" THAT NEEDED VENTING !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 10-21-2009, 01:11 PM   #9
Macplumb, lots of outhouses are vented.
Old 10-21-2009, 08:23 PM   #10
Otherwise they blow up when you light your cig.
Gary
Gary_602z is offline   Reply With Quote
Old 10-21-2009, 08:49 PM   #11
You are so wrong
Anti-wingnut is offline   Reply With Quote
Old 10-22-2009, 01:28 PM   #12
Originally Posted by Anti-wingnut View Post
You are so wrong
Section P3105.1 of the International Residential Code 2003 states:
"The developed length of the fixture drain from the trap weir to the vent fitting for self-siphoning fixtures, such as water closets, shall not be limited..."
I guess my statement was technially incorrect. What I meant to say is toilets do not require a separate vent. The stack itself is the vent.
Old 10-22-2009, 07:21 PM   #13
While you are trying to justify your answer you are still wrong.
What that is refering to is the developed length of the drain from the trap weir. Because a drain line from a trap weir depending on what size pipe is used is limited to a specific length.
So if a toilet drain is connected to a stack at any lenght will require a vent, wether a common, individual vent or wet vent by a bath group
We won't talk about when six toilets are on the same drain and require a relief vent.
What you posted just stated that the developed drain has no limit to length because it's a toilet
More On This Topic
Chemical toilets are located in areas such as airplanes, recreational vehicles and boats. They also offer a sanitary solution when a conventional toilet is not practical. There are a few guidelines to follow when you decide to use a chemical toilet to... Read More »
Hi. I'm Albert Hedgepeth with Expert Village. Today we are going to talk a little bit about boat maintenance. What we are going to talk about now is a macerator. A maceration system is used to chop up sewage that is on your boat and the discharge from... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
On a boat, they call the toilet the head. So on this boat, this is what we call a head. It has the toilet in it and it has also a dual purpose shower. Now toilets or heads on sailboats are kind of a little complex animals, so there's two parts to it. You... Read More »
Toilet papering a house is a good prank among friends. It is not destructive and fairly easy to clean up. It is also a lot of fun to do. Read More »
Running a natural gas line Roger General Discussion 2 02-27-2009 09:42 AM
waste line in basement slab 7474 Plumbing 6 12-11-2008 08:38 AM
Toilet running inside bowl leroyme Plumbing 4 08-21-2007 09:50 PM
Toilet Keeps Running Rod Plumbing 5 01-28-2007 09:39 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 11:36 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
