Toilet Wast Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2009, 12:24 PM   #1
Smile
Toilet wast pipe
Hi
Hope someone can help.
I am about to fit a new toilet but need to check on the regulations. I have looked through the building regs part H but found no joy. Is it possible to turn right from the pan then go straight for about 3 feet through the external wall then right again for another 1 foot into the stack? I have been told informally that i can only have a bend every 6 feet. Is this correct?
Neil
neilju is offline   Reply With Quote
Old 04-28-2009, 01:15 PM   #2
BIGRED
Rewards Points: 252
Get a plumber pal. They put in closet bends directly below the toilet flange so the waste gets a fast vertical fall for momentum. That's one 90 degree turn. The best course for your waste to follow is a direct path to the 4" main stack. Don't try to build in an obstacle course for it or you will be on the end of a plunger for ever.
Grampa Bud is offline   Reply With Quote
Old 04-28-2009, 01:37 PM   #3
Thanks for reply.
I will get plumber to fit the new suite but i need to plan the partition wall first. i hope to run the pipe right from the toilet and then one final 90 degree turn into stack. Do you know if this is possible?
Old 04-28-2009, 02:53 PM   #4
Rewards Points: 352
You need to use the proper radius and at least 3" pipe. I am not aware of an limit to the number of bends only the radius of the bends. I don't understand the part about a "pan" or the "external" wall. Usually a toilet is plumbed from under the floor and the waste would route in the bay of two joists to a stack. If you can provide a better description maybe I could be more help.
Rege
Rege
RegeSullivan is online now   Reply With Quote
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
