Toilet - Wall Distance - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2008, 11:58 AM   #1
Remodeling a bathroom... currently the toilet centerline is placed 16" from the room's wall. Is this too tight? Is there a standard distance the toilet's should be kept off the walls? I can move it, but I don't want to unless I absolutely have to OR it would be considered really weird otherwise. Thanks,
Pineapple is offline   Reply With Quote
Old 11-03-2008, 12:31 PM   #2
Rewards Points: 1,910
Code in most places is 15" from the side wall so you are ok. That is the minimum so a greater distance might be more comfortable.
Old 11-03-2008, 12:52 PM   #3
Thanks for the clarity on the code. Looks like I'm good there, but I'm also concerned with the comfort aspect. I have the room to move it - with plenty to space. My concern is that it will look odd being slammed against the wall with so much room to play with between the vanity. However, moving it could be a real pain as I'd much rather use all the existing plumbing! Is there a comfortable rule of thumb distance that is commonly used when designing bathrooms?
Old 11-03-2008, 01:10 PM   #4
Lots of them are at the minimum. Take a tape measure with you and visit several bathrooms - see which ones are and aren't comfy. If it's already 16" I'd be hesitant to move it but if for some reason you need the room now would be the time to move it.
If you have extra room between the vanity and toilet you can go with a wider vanity, put a trash can there, slide in a linen cabinet - something along those lines rather than move the toilet.
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
