Toilet W/Fluidmaster Slow Filling - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2010, 06:52 PM   #1
Toilet w/Fluidmaster slow filling
I have a Fluidmaster system in my toilet that is really slow filling lately.
I tried to replace the valve, but it actually made the top of the tower (where the valve goes) leak. Exact same valve as the old one but new... strange. I put the old one back on, and tried to flush out the tower and the pressure seems fine.
Any thoughts?
paulo75 is offline   Reply With Quote
Old 09-04-2010, 07:24 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Have you checked to see if the shut-off valve to the toilet is fully open with no debris inside the valve?
That can cause this to happen.
Turn the water main off and remove the toilet valve handle. Put a towel over thy toilet shut-off valve and have someone turn the water main on and off very briefly. That should flush out any debris.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-04-2010, 08:25 PM   #3
Actually just tried that, and no luck. O
ne thing I noticed though was that it sometimes takes a few flushes to get all of the contents down the bowl, and the toilet will then fill past the fill line...
Old 09-05-2010, 08:46 AM   #4
the fluid master has a seal on top that you can change out. Couple $ for the part. As for the flushing, that is different, you may have a partial clog in the line. Try plunging the toilet,, and as for water going above the "fill line", there is an adjustment on the fill valve, when you replaced the old one, you might of pulled it up resulting in higher water level. Fluid masters are pretty easy to work on.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 09-05-2010, 09:23 AM   #5
That's what I did.. I changed the seal (I said valve in the original post)... the new seal caused it to leak.
Fluidmaster - Slow filling toilet ronniecr Plumbing 12 06-18-2014 06:49 PM
slow flow into toilet bowl ... plz help!!! dainty Plumbing 0 08-29-2010 01:29 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
