Old 11-07-2009, 06:54 PM   #1
Default toilet venting problems
My house is approximately 16 years old and I am having problems with the flushing on the 2nd story. When I flush either of the 2 flushes on the 2nd floor, they flush okay but they then pull air from the tub or sink drains. This causes odors to come through these traps. I have been in the attic and know the vent pipes are connected and I have run a hose from the vent exit on the roof and there doesn't seem to be any blockages.
Any ideas why the flushes are pulling air from the drains.
kimmik is offline   Reply With Quote
Old 11-07-2009, 07:04 PM   #2
Master Plumber/Mechanical
Did this problem just start
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 11-07-2009, 08:11 PM   #3
No. It has been like this for some time
Old 11-08-2009, 12:50 AM   #4
Has it been doing this the whole time you have lived there?
plumber Jim is offline   Reply With Quote
Old 11-08-2009, 10:05 AM   #5
I think pretty much but it seem to have gotten worse.
Old 11-08-2009, 03:03 PM   #6
I wonder if it was ever vented then.
Old 11-08-2009, 03:46 PM   #7
That's what I think. Is there any thing that can be done now to help or are there any type of flushes that are better than others for these problems.
Old 11-08-2009, 04:18 PM   #8
my next question would be can you be sure that the Lav sinks and the tub is vented? If so try and check to see if those vents are open. because If the are vented then it should pull air from their vent and not their traps.
Old 11-08-2009, 04:19 PM   #9
Oh, can you post a picture of the venst in your attic? lets try and get a feel for what is the vent for what.
Old 11-08-2009, 04:41 PM   #10
is it possible vents are in a wet vent situation to the toilet?
Old 11-08-2009, 05:43 PM   #11
The venting is covered in insulation. I know that there is a vent pipe going to both bathrooms as I could follow them under the insulation
Old 11-08-2009, 06:03 PM   #12
Do both vents that you followed connect and then go through the roof or do both vents each go through the roof
Sometime the pipes are connected in the attic ( Manifold connection) and then go through the roof. A bird or squirrel could have gone down the pipe and blocked the vent
Old 11-08-2009, 06:14 PM   #13
Actually they connect in the attic and go out in one pipe.
I took a hose and run it in the vent on the roof to make sure there were no blockages and the water ran through no problem
Old 11-08-2009, 06:23 PM   #14
Sure but if one is blocked and one isn't where do you think the water went
Down the one that isn't blocked.
Still doesn't prove you don't have blocked vent
What you are going to need to do is seperate the vents in the attic and snake each vent
Old 11-08-2009, 06:31 PM   #15
Good point. I think I will get a plumber to come and look at.
I hope that it is a simple blockage but I suspect it is a problem of them not being vented.
My problem is that the original plumber I had was who John Wayne had in mind when he made your attached quote.
Thanks for your feedback
More On This Topic
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
Forcing the trap of the toilet is a great way to empty the toilet completely before you remove it. Forcing the trap is also a good way to unblock the drain. If something gets dropped in the toilet, too much toilet paper gets stuck or something else... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I am going to take you through step 3 in our procedure for flushing a cooling system. Once your coolant has started to come out almost clear, you are going to go ahead and turn off your... Read More »
How to Flush a Boat Engine
How to Flush a Boat Engine by Expert Village
Hi I'm Albert Hedgepeth with Expert Village. Today we are going to talk a little bit about boat maintenance. Whenever you pull a boat out of water; especially if it's been in salt water for awhile, with inboard engines and outboard engines you are going... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Toilet Problems akim1220 Plumbing 3 08-27-2009 12:11 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 4 01-11-2009 01:06 PM
Toilet jpark Plumbing 18 01-05-2009 09:12 AM
Toilet Problems Willie5566 Plumbing 7 07-26-2008 09:42 PM
toilet problems... sflamedic Plumbing 3 07-31-2007 12:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
