Toilet Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 10:23 PM   #1
Toilet Venting
Is it ok to vent a toilet as in the attached image? Specifically, can I use a san-t here? Or do I need to use a wye or combo?
mlitcher is offline   Reply With Quote
Old 04-03-2013, 06:54 AM   #2
Rewards Points: 2,512
3rd photo top row. Wye--stub--45
Photo is from Bert Polks plumbing handout Lincoln County.
Im curious also to see if your photo would be OK or if that would be considered a flat vent. Do you have an issue with height before you get to a wall for venting is that why you want to vent vertically first
hammerlane is offline   Reply With Quote
Old 04-03-2013, 09:56 AM   #3
Ok, I can do that too (use wye). I had seen a similar image to that as well. I was just curious if the san-t was ok, in my situation it was less fittings and takes up less vertical space.
I need to actually rotate that 90 to point at the stack and I was going to run the vent in the wall behind the toilet. There is a vent there that I can tap into. I've got plenty of vertical space below though, this is a first floor bathroom, so lots of room.
Old 04-03-2013, 11:54 AM   #4
Rewards Points: 1,706
Only if your picking up a lavatory sink with that vent. What you have then is a wet vent. If you are not doing that then it would be illegal per IPC. You are not allowed a dry flat vent below the fixture it would tend to clog then you will have no vent.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
fetzer85 (04-03-2013), Javiles (04-03-2013)
Old 04-03-2013, 12:54 PM   #5
Got it, that makes sense. I could potentially redirect the lav down that.
If I don't connect the lav though, would the layout attached be considered a dry flat vent as well?
Old 04-03-2013, 03:08 PM   #6
Put a lav on it it is legal. No Lav it is no longer legal.
The lav acts as a wash out of the vent. It will also stop working if the vent becomes blocked. You will then snake the lav to re open the vent.
IPC code only I cannot speak for other areas of the country.
The Following User Says Thank You to Ghostmaker For This Useful Post:
existing venting ok for new toilet, sink, and washing machine? dingeman Plumbing 2 07-14-2012 12:36 PM
Adding a Bathroom in a bungalow attic - Toilet Venting awpurcell10 Plumbing 4 06-08-2011 08:22 AM
Moving toilet 12 feet, unsure about venting sputnik62 Plumbing 11 05-10-2011 04:32 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
