Toilet Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 08:41 AM   #1
Toilet venting
In venting my toilet do I have to go through the roof? I was wondering if I could run the vent pipe higher than the toilet tank and then loop it back down and run it to the outside through the basement. I already have a main stack vent in the system. This is for a toilet in an addition.
Brandomatic is offline   Reply With Quote
Old 07-07-2012, 09:17 AM   #2
Rewards Points: 3,130
Do you know which plumbing code applies where you live. If it's the IRC (like where I live), the toilet doesn't require a vent.
But to answer your question: no, I don't think you can do what you asked about. What you can do is run the vent up into the attic and tie it into an existing vent. That will avoid another roof penetration.
Old 07-07-2012, 09:40 AM   #3
Thanks for your reply. Code is not an issue - my main concern is that the toilet functions properly. I bought a new efficient toilet, 1.28 gpf, and it has to travel approximately 35 feet to the septic. Is no venting still ok?
Old 07-07-2012, 09:41 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Out of here....
Journeyman Plumber
Old 07-07-2012, 09:42 AM   #5
Doing it myself
Alan's Avatar
LULZ..... I'm out of this thread.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
ben's plumbing (07-08-2012)
Old 07-07-2012, 11:13 AM   #6
The issue isn't how far from the toilet to the septic, it's from the toilet to the main stack. Under the UPC, the maximum distance without having a secondary vent is something like 5 or 6 feet. Under the IRC, there's no distance limit, and no secondary vent is required. The two codes approach venting very differently, but both work. But, then, if you don't care about the code, why are you even asking your question?
Old 07-07-2012, 12:25 PM   #7
I just wanted to make sure that it would flush properly without it.
Old 07-07-2012, 12:43 PM   #8
Doing it myself
Alan's Avatar
Journeyman Plumber
Old 07-07-2012, 02:02 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 550
But I thought you said codes were not an issue?
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Alan (07-07-2012), ben's plumbing (07-08-2012)
Old 07-08-2012, 12:55 PM   #10
Toilets plumbed either way will flush just fine. The point is, is not having a vent legal where you live??
Old 07-08-2012, 09:39 PM   #11
Rewards Points: 582
what the .......... wow your kidding right....
Old 07-09-2012, 08:23 PM   #12
If you're addressing your post to me, then no, I'm not kidding. Are you not familiar with the IRC?
Adding a Bathroom in a bungalow attic - Toilet Venting awpurcell10 Plumbing 4 06-08-2011 07:22 AM
Moving toilet 12 feet, unsure about venting sputnik62 Plumbing 11 05-10-2011 03:32 PM
Venting a toilet Itchbo Plumbing 2 01-17-2011 05:27 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
