Old 01-23-2012, 09:33 AM   #1
Toilet ventilation problem
Master bath (toilet-1), guest bath (toilet-2), approximately 6 feet apart.
toilet-1, when flushed, sucks water out of toilet-2.
toilet-2, when flushed, water in toilet-1 shakes slightly, but not sucked out.
Toilets are "Kohler 1.6 gal per flush".
These replacement toilets were installed a couple of days apart.
I re-installed toilet-2 again recently, but no change!
How do I go about finding the vent problem?
nelsonb is offline   Reply With Quote
Old 01-23-2012, 10:44 AM   #2
Do you know if the master stack is between the two bathrooms? In my place the toilets are side by side with the master stack in between. If you are not sure, look at the roof and see if a big vent pipe comes out of the roof in that approximate area.
Where are you?
B
Beepster is offline   Reply With Quote
Old 01-23-2012, 02:30 PM   #3
Sounds like toilet 2 is improperly vented....maybe wet vented. Is there a crawlspace or some way to get a picture from underneath?
JeepNick is offline   Reply With Quote
Old 01-24-2012, 09:49 AM   #4
I'm located in Cincinnati, Ohio.
Recently, I went on my roof and ran a hose into the vent pipe.
Using a pressure "bladder" on the hose I was able to feed 23 feet of hose into the vent pipe and power sprayed for 30 minutes - NOTHING CHANGED.
Old 01-24-2012, 10:20 PM   #5
Master Plumber
Javiles's Avatar
Was this happening with the old toilets? You may have to go in with a camera and check, which line needs to be corrected you may not have to re vent the system, depending on the conditions and layout of the plumbing in your home you may be able to add a relief vent. Good luck
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 01-28-2012, 09:55 AM   #6
I should have answered your first question, sorry.
The master vent stack is between the two toilets, based on the location on theroof.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet flushing problem jules81 Plumbing 4 06-02-2008 02:06 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 11:33 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
