Toilet Vent Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2007, 04:39 PM   #1
toilet vent problem?
I have second floor toilet that does not flush correctly. When flushed, the water will rise very high (approx 2" below rim) before the water will actually start to flush down the drain. Then the water level drops very low, almost now water is left in the toilet. Could this be caused by a clogged vent or is it just a bad toilet design?
docholaday is offline   Reply With Quote
Old 06-11-2007, 07:05 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Seen this many times and most of the time the tank fill valve is the problem, with in not working right, it can cause problems with the operations of the toilet, so replace the fill valve and see if that will solve this problem.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-12-2007, 11:07 AM   #3
I've also had this problem when the drain (not the vent) is clogged. I'd start by snaking it. I'll bet somethings stuck in there.
NateHanson is offline   Reply With Quote
Old 06-12-2007, 03:46 PM   #4
Me too have similar problem before due to drain clogging... the issue can be resolve after clean up the clogging... but then will come back later on... the source of the crime is Builder use a cheap toilet which either have a small drain hole or bad design... I replace the toilet with "American Standard" then everything is so smooth and I dispose the plumb stick.
KUIPORNG is offline   Reply With Quote
Old 06-12-2007, 07:04 PM   #5
Journeyman Plumber
Odds of it being a 2nd floor mainline stoppage is slim, I stand by my solution, but if you really want to pull the upper floor toilet, run a cable, go for it.
Your choice, what do I know?
Old 06-13-2007, 12:34 AM   #6
That one Guy's Avatar
How old is the toilet?
Do all the jets work including the main one in the bottom of the bowl?
Have you checked to make sure there is not an object in the toilet trap?
That one Guy is offline   Reply With Quote
Old 06-13-2007, 09:40 AM   #7
The toilet is probably pretty old. It was in the place when I bought it. I recently remodled the bathroom and I checked the toilet drain when I had it off and it didn't seem to be clogged or have anything in there that would cause a flow restriction. I also recently replaced the flapper, so I don't believe that the valve would have anything to do with the bad drainage (i.e. the water fills to the correct level in the bowl). Sounds like maybe it's just a bad toilet design?
Old 06-13-2007, 11:19 AM   #8
When I had this problem, I ended up taking the toilet off the flange, and found a q-tip, perfectly wedged across the opening at the bottom of the toilet, where it met the flange. Plucked that out, and all was fine.
I'd start by snaking the toilet trap and/or removing the toilet to make sure it's not obstructed.
Old 06-21-2007, 06:05 PM   #9
Union HVAC Tech.
How could the fill valve cause the water to rise up high in the bowl when flushed?
I can see it causing an issue with refilling the tank.
bigMikeB is offline   Reply With Quote
bathroom vent fan - condensation problem jaspar General DIY Discussions 16 03-23-2012 11:54 AM
Toilet cistern problem pmasalawala@talk21.com Plumbing 5 08-07-2007 04:38 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
toilet rough-in problem christinalee Plumbing 1 12-31-2005 06:37 PM
