Toilet Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2013, 02:28 PM   #1
Toilet vent
I'm installing a bathroom in the unfinished upstairs of my cape and need help with proper vent for the upstairs plumbing. I've attached a sketch of how I plan on venting but want clarification to make sure this will work. My main concern is having the vent come in behind the toilet.
Thanks for any thoughts.
UpstateNYDIY is offline   Reply With Quote
Old 03-21-2013, 09:10 PM   #2
Rewards Points: 1,678
What code is being used for plumbing in your area?
Under the IPC the vent for the toilet is illegal it is flat and not washed out.
The fitting to the lav sink must be a y type fitting off the 3 inch
You cannot have a bath below that is using that pipe as a vent if that be the case.
So what you need to do under the IPC is just turn up for the toilet use a y fitting off your 3 inch and pick up your lav and vent that lav as drawn. Make sure you increase the vent to 3 inch out the roof. 12" below and 12" above roof. As long as your not using pipe from 3 inch vent from a first floor fixture. And pull all permits as required. Unless you like inspectors have you rip drywall out later.
Ghostmaker is online now   Reply With Quote
Distance from toilet to vent. Rclancyc Plumbing 9 07-30-2012 04:34 PM
toilet vent removal DIYfirsttimer Plumbing 1 06-13-2012 10:27 PM
plumbing layout .. toilet vent / main vent ? beachfront71 Plumbing 0 06-17-2011 03:33 PM
Toilet vent in upstairs sink line DavidT Plumbing 1 02-28-2009 08:29 AM
toilet vent problem? docholaday Plumbing 8 06-21-2007 06:05 PM
