Toilet Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2010, 08:55 PM   #1
Rewards Points: 1,088
Toilet Valve
I'm planning on replacing a few toilet valves.
  1. Should the hoses connected to the shutoff valves be replaced also?
  2. Also, one of the hoses is pex. Does that hose need to be replaced by pex also, or can it be regular braided hose.
  3. Is tubing really for looks, or does it work better than braided hose? How much bend can tubing take?
handy man88 is offline   Reply With Quote
Old 05-18-2010, 09:48 PM   #2
Do something
D'Brie's Avatar
  1. Should the hoses connected to the shutoff valves be replaced also? YES, always.
  2. Also, one of the hoses is pex. Does that hose need to be replaced by pex also, or can it be regular braided hose. Use braided supply.
  3. Is tubing really for looks, or does it work better than braided hose? How much bend can tubing take? It's chrome plated copper. If you are not going for looks, go braided supply. If you are careful, it will bend quite a bit but you should not go beyond 90 degrees.
D'Brie is offline   Reply With Quote
The Following User Says Thank You to D'Brie For This Useful Post:
handy man88 (05-18-2010)
Old 05-18-2010, 11:13 PM   #3
Is it necessary to use Teflon tape on fittings and what is the general size of the braided hose to be used?
Old 05-18-2010, 11:28 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Use teflon tape or pipe dope on tapered fittings and pipe. Do not use on compression fittings.
In general, the braided hose is 3/8" with a 3/8" connection on the angle stop end and 7/8" connection on the toilet end. The braided hose should have a tag on it stating either "toilet supply" or "closet supply".
JDC is offline   Reply With Quote
The Following User Says Thank You to JDC For This Useful Post:
Old 05-18-2010, 11:43 PM   #5
Why is it not recommended to use pipe dope on compression fittings?
Also, I was at HD today, and some lady was telling me her plumbing nightmare about how her plumber can't seem to fix a leak on her shutoff valve on the compression nut side.
Is it true that if you replace that shut off valve, that you will need to cut off the section that the ferrule has made an impression into and start on a new section?
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 04:34 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
