Toilet Tub Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2008, 12:47 PM   #1
Rewards Points: 150
toilet tub placement
what is the minimum distance between the outer edge of a tub and the center of a toilet flange. also if anyone knows, what should i use to drill holes in fiberglass tub?
drewhart is offline   Reply With Quote
Old 08-14-2008, 01:14 PM   #2
Registered User
Termite's Avatar
Per the IRC code, the water closet's centerline must be at least 15" off of the finished wall, or in this case, the tub.
What kind of holes are you wanting to drill in the tub? What are they for?
Old 08-14-2008, 01:17 PM   #3
Rewards Points: 150
the holes are for the water handles. there are two holes already, one for the drain and overflow, but i need holes for the water shut handles and for the spout.
Old 08-14-2008, 01:19 PM   #4
Rewards Points: 150
the tub is a one piece tub shower surround. i thought the closet's centerline should be 12'' from the finished wall?
Old 08-14-2008, 02:44 PM   #5
Send a message via AIM to Marlin
15" is code. Think about sitting in a two foot box, it's not the most comfortable spot. If you are a real big guy you may end up not even making it into that space.
Marlin is offline   Reply With Quote
Old 08-14-2008, 03:08 PM   #6
47_47's Avatar
Rewards Points: 76
12" to the back of the tank and 15" from both sides and the front.
47_47 is online now   Reply With Quote
Old 08-14-2008, 05:07 PM   #7
Rewards Points: 150
well using a 45 degree street elbow it now it 12'' from the tub. do they make 60 degree street elbows?
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet spacing issues... KC10KEVIN Plumbing 4 05-08-2008 11:27 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
Toilet Placement moneymgmt Plumbing 5 02-11-2008 11:32 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
