Old 07-25-2010, 10:02 AM   #1
toilet troubles
we bought this house about two years ago. all the work the previous owner did on the house is/was hacked at best. he redid the plumbing waste line and never hooked the stink pipe back up. also, i feel he didn't put an appropriate angle on the pipe. anyway, the toilet will not flush correctly about 75% of the time. when we first moved in the toilet flushed fine and progressively got worse over time. i believe it has to do with a lack of stink pipe, but all the other sinks and the tub drains fine. any ideas?
neight is offline   Reply With Quote
Old 07-25-2010, 12:33 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
toilet troubles
There should be a drain line slope of 1/4" per linear foot toward the sewer/septic system.
A toilet has its own built-in trap, and the drain line has to be vented a few feet from the toilet with a vent stack through the roof. A toilet drain line and stack should either be 3" or 4".
It will never work right without a vent.
Sounds like it needs a replumb job.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-25-2010, 04:10 PM   #3
toilet troubles
that's what i was afraid of. thanks for the reply!
cheers!
nate
Old 07-25-2010, 05:40 PM   #4
toilet troubles
If the toilet worked fine before and is getting worse over time it is not a venting problem. Either the drain is getting clogged or it is an issue with the toilet itself,
SuperPlumberGuy is offline   Reply With Quote
Old 07-26-2010, 04:17 PM   #5
toilet troubles
thanks, i'll look into that as well.
cheers!!
nate
Tags
toilet vent
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
